|  02-24-2010, 09:40 PM | #16 |
| Rotary Fan in Training Join Date: Feb 2010
				Rep Power: 0  |
			thats something I haven't thought of. I will fill the system from the highest point and see what happens. I have 2 radiator caps. one in the front and one on top ot the waterpump fill neck. The one up front has leaked before. maybe I need a higher pressure cap up front?
				__________________ 74 porsche 914 with 13b rotary http://www.youtube.com/watch?v=d0CUlLecxbo 73 914 porsche 1.7 |
|  02-24-2010, 09:43 PM | #17 |
				Rep Power: 0  |
			how do you perform a propper pressure test?
|  02-25-2010, 02:00 AM | #18 |
				Rep Power: 0  |
			This may be a very dumb question, but when you first start a car and the thermostat is closed so that the engine can warm up, what happens to all the coolant that the water pump is still trying to push? Seems like it has no where to go since it is not looping through until the thermostat opens.
|  02-25-2010, 07:56 AM | #19 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
			I always wondered that too. I guess it just cavitates withing the water pump housing until the thermostat pops.
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
|  02-25-2010, 09:19 AM | #20 | ||
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  | Quote:
 You want to bleed the system at the highest point last. Something you might want to add to the system is an expansion tank, I swear by them now. Installed properly they will automatically and constantly bleed the system unless there is an air bubble big enough to jam up the waterpump. If that happens you're screwed and the temp will just skyrocket. With air in the waterpump, the coolant will not move at all. With a proper pressure tester. With the car cool, hook this little tool up to the rad cap, which ever one, and pressurize the system to 110% of the cap and watch for the leaks. Quote:
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- | ||
|  02-25-2010, 12:44 PM | #21 |
				Rep Power: 0  |
			Originally Posted by craig3x   This may be a very dumb question, but when you first start a car and the thermostat is closed so that the engine can warm up, what happens to all the coolant that the water pump is still trying to push? Seems like it has no where to go since it is not looping through until the thermostat opens. "it flows through the heater core (if it's open) and weeps through the t-stat". hmmm, but I don't have a heater core. And I guess my question is that if I installed one of those fancy 50gph electric pumps, what would happen when the thermostat is closed? sounds like major pressure build up???
|  02-25-2010, 01:40 PM | #22 | |
| I-had-a-bad-experience... Join Date: Feb 2008 Location: M'boro
				Rep Power: 19  | Quote:
				__________________ '15 Juke Nismo '06 MX-5 GT SOLD '04 S Silver RX-8 GT Track Day Use SOLD '90 Black TII vert w/ Sprint RE stock port/turbo DD dyno (242.6whp@5500rpm @12psi 8psi@redline) and (250ftlbtq@4800rpm @13psi) SOLD '89 GTUs 6p TII SOLD, '87 sport SOLD, '79 SA stock SOLD '91 B2600i 4x4 w/ Rx-8 LSD SOLD | |
|  02-25-2010, 02:03 PM | #23 |
				Rep Power: 10  |
			Or wire it so that it doesn't come on until your t-stat is open
|  02-25-2010, 02:08 PM | #24 | |
 wouldn't no water flow create weird hotspots in the engine?
|  02-25-2010, 03:42 PM | #25 |
| Rotary Fanatic Join Date: Mar 2008 Location: Brenham, TX
				Rep Power: 18  |
			I use a 16 psi cap. Coolant Pressure is related to the temperature of the coolant. As the coolant gets hotter it builds up more pressure. if your cap is old and weak or rated too low for your application the water will escape, this means it's not cooling the engine. Usually you have a water reservoir that catches the water, and when the coolant cools it sucks it back in. If you run a cap pressure too high, this puts extra pressure on the coolant hoses and seals under overheat conditions. I prefer to run a higher then stock pressure cap, this insures the coolant is still trying to cool the engine if temps ever do get high. A system under normal operating temps will have the same pressure with a 16 psi cap as it will with a 13 psi cap. The only difference is when the temps go higher the 13 psi will boil over quicker. hope this helps. And given your somewhat complicated system I wouldn't be surprised if you have air in your system. There is a special coolant burping funnel that is supposed to work well for this. I would try to burp your system over several days to insure no air is in there.
				__________________ 500+ HP thanks to:  Fast reacting IAT sensor thread! Mechanical Pre-turbo Water Injection Thread Dual Stock fuel pumps Thread T2 differential swap! |
|  02-25-2010, 03:55 PM | #26 |
				Rep Power: 18  |
			Also most all cooling systems that i know of have a bypass, either external or internal. Usually they are always open. this allows the coolant to still circulate around in the engine  resulting in a more uniform temperature across the whole engine, which aids efficiency and reduces wear on internal parts. Otherwise you would end up with certain spots much hotter then others, and who's to say the coolant where the Tstat is located would ever get hot enough to open before damage occurs somewhere else?
|  02-25-2010, 03:59 PM | #27 | ||||
				Rep Power: 10  |
			Maybe but not much more than a stock system Quote:
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- | ||||
|  02-25-2010, 04:25 PM | #28 |
				Rep Power: 18  |
			They will have the same pressure until the lower rated cap allows coolant to boil over. The PSI rating of the cap has no effect on the pressure until the pressure overcomes the cap.
|  02-25-2010, 05:31 PM | #29 |
				Rep Power: 10  |
			right, and the extra ~10* of cooling before the coolant starts to boil is of no need to us.  Basically there is no need to run a 16psi cap if you're using a 50/50 mix.  To me the extra 3psi places on the seals/hoses isn't worth it.  Hell, I think we should all be running Evans, but I pull my motor too often for that
|  02-25-2010, 05:44 PM | #30 |
				Rep Power: 0  |
			hope this helps. And given your somewhat complicated system I wouldn't be surprised if you have air in your system. There is a special coolant burping funnel that is supposed to work well for this. I would try to burp your system over several days to insure no air is in there.[/QUOTE] you're right. I did have air in it from a previous boil over. I filled it on the side of the road, but didn't "burp" it. Thanks. However, I still think I may have a problem by trying to use a stock waterpump to push coolant through about 12 ft of hoses
