Old 06-10-2009, 07:58 PM   #1
josh18_2k
FC OEM rear sway bars?
i hate to make a thread for this..
is there a difference among OEM FC rear bars? is TII/vert bar thicker than an NA?
I'm looking for the stiffest of the OEM's
Old 06-10-2009, 08:48 PM   #2
I believe they are but can't say for sure... it's been awhile since I researched it. (I ended up going racing beat sway bars anyways)
Old 06-10-2009, 09:02 PM   #3
I believe they are different. If I'm remembering clearly the SE and Vert models came with a 12mm rear bar and the GXL/T2/GTU had the larger 14.5MM rear bar. I want to say you can verify this with the part numbers for factory replacement bushings for the rear...
The part I cant recall is if it changed at all for S4 to S5....
Old 06-10-2009, 09:48 PM   #4
I believe it's divied up by
4 lug = 12 mm
5 lug = 14 mm
I actually removed my rear bar and so far like it. It pushes a LITTLE but I still need to finish aligning and cornerbalancing before I start playing around with different bars
Old 06-10-2009, 11:17 PM   #5
josh18_2k
my setup is far from stock. i'm currently without rear bar, and i need a little better turn in. front is adjustable, so i can always add more in if needed.
Old 06-11-2009, 01:24 AM   #6
Rx-7fetish
Blue Blur
Rx-7fetish's Avatar
I believe the s4 the turbo is thicker than n/a, and then when they went to s5 both turbo and n/a are the same. Im not sure if they shrank the turbo to the same as the n/a in s5 or if they beefed up the n/a to the same as the turbo. Thats what i remember. I couldnt for the life of me tell you if the numbers so far posted are correct or not but im gonna just nod and agree so i dont look dumb lol
Old 06-11-2009, 01:45 AM   #7
if you're running coil overs, and other rear end stuff like solid bushings in the control arms, double camber adjusters, etc, then it's actually better w/o a rear swaybar.
Have you considered replacing your rubber control arm pivot bushings with solid ones?
Old 06-11-2009, 10:35 AM   #8
87 t-66
87 t-66's Avatar
87 t-66 is on a distinguished road
ive got a t2 rear bar for cheap if you need it.
87 T2
90 T2 'Vert
87 t-66 is offline   Reply With Quote
Old 06-11-2009, 12:03 PM   #9
josh18_2k
i dont have any rubber parts.. its all poly and sperical, adjustable everything.
i had a ST rear bar, then no rear bar. i want something in the middle (OEM)
anyway, i just want to trade my ST bar for a stock thicker one + cash
Old 06-11-2009, 11:56 PM   #10
What's the thickness on the ST bar? Is it adjustable? Comparision to the RB bar? I MAY MAY be interested. I still have a lot to sort out so having a stock TII bar in the mill may be beneficial to me.
Old 06-12-2009, 03:51 PM   #11
josh18_2k
ST rear bar is not adjustable, and from what i read "its the thickest you can buy"
i dont have calipers, so i could try to measure it but it may not be right.
Old 06-12-2009, 04:15 PM   #12
Flooder
Flooder's Avatar
Flooder is on a distinguished road
I took my rear sway bar off and I get somewhat more traction whilst drifting. *shrugs*
If you're that worried about sizes, get a tanabe way bar, its thick as shit.
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 06-15-2009, 12:13 AM   #13
josh18_2k
im not looking for a thick bar, i'm looking for a thinner one. i already have an ST bar and its too beefy.
OEM should be just fine
Old 06-17-2009, 11:52 PM   #14
Black91n/a
Black91n/a is on a distinguished road
According to the factory service manual the bars are as follows:
S4 w/o harder suspension: Front = 22mm, Rear = 13mm
S4 w/ harder suspension: Front = 24mm, Rear = 13mm
S5 w/o harder suspension: Front = 24mm, Rear = 12mm
S5 w/ harder suspension: Front = 24mm, Rear = 14mm
So for the rear it would seem that there are 3 choices: 12mm, 13mm and 14mm.
I'll usually check the FSM for stuff like that, as it's full of useful information.
Black91n/a is offline   Reply With Quote
Old 06-18-2009, 12:31 AM   #15
hrm, I thought there were only 2 different sized, 12 & 13
