Old 12-09-2008, 06:17 PM   #16
firzen
Originally Posted by JL1RX7 View Post
Yea check the screws on your brake rotors. I had one that came loose and it caused some strange clunking noises. I was suprised since I would have thought the lug nuts would have held it tight.
I never put the screws back on when I did my brakes- they are more of a source of trouble IMO than anything. If anybody has experience to the contrary, feel free to let me know.
I've heard stories from people that didn't torque their lug nuts and suffered the consequences. IMO it is a simple thing to remedy and not a bad habit to check the torque on them every so often.
Old 12-10-2008, 01:32 PM   #17
JL1RX7
Frizen, I thought the same thing. Torque the wheels and the should be held tight. But I have the screws in ther and it started to back out and the rotor would make that noise like it was loose. Checked and re-checked the torque on the lug nuts. Only went away when i tighted up those screws. Noise went away and well that was all I did.
Old 12-11-2008, 05:05 PM   #18
Rotary13B1
Rotary13B1's Avatar
Rotary13B1 is on a distinguished road
Torque those nuts to 90lbs.
Note: The noise was not present when I tried to replicate it today, turned the car on, no noise when the car/brakes are cold... Bro in law, suggested we take a closer look at the wheel bearings/hub assembly.
On that note, anyone have a spare 5 lug hub assembly lying around?
RCC Vendor & Supporter!
Rotary13B1 is offline   Reply With Quote
Old 12-11-2008, 05:59 PM   #19
Fidelity101
Reliable Source
Fidelity101's Avatar
they are impossible to get off unless you have a impact hammer or whatever its called.
My Rx-7 Vids
Old 12-11-2008, 10:59 PM   #20
JL1RX7
Yea, had to use that to get mine out, put anti-seize to try to keep them from doing that again, but with all the heat that goes throught there it will be a matter of time before you need that impact screwdriver to back tham out.
Old 12-12-2008, 11:20 AM   #21
mfisher12
mfisher12's Avatar
mfisher12 is on a distinguished road
try using some PBC grease or anti-seiz to lube the caliper slides and the back and ends of the pads....ive had that take care of the same noise before...also make sure that the springs aren't binding
mfisher12 is offline   Reply With Quote
Old 12-14-2008, 10:20 AM   #22
farberio
farberio is on a distinguished road
I used allen head screws so I wall have more leverage when I do mine again.
farberio is offline   Reply With Quote
Old 12-14-2008, 10:22 AM   #23
farberio
I probably would not use Anti-seize when there is specific brake pad stuff out there for super cheap. Besides...if any of that anti seize gets on your brakes or rotors your royally pwned.
Old 12-15-2008, 08:54 PM   #24
NoDOHC
NoDOHC's Avatar
I use the Allen head screws from fastenal myself. (I do have access to an impact screwdriver, but it only rings the bolts off in the hub and you have to clock the rotor differently next time.)
I found my clunk problem by jacking the car up and dropping it while watching the suspension (mine also clunked when going over bumps at low speeds).
If you could have somone walk beside you with a flashlight and watch if anything moved as you moved slowly and then braked it could help you a lot.
(The front calipers have no slides that I am aware of, so I doubt it is that).
Old 12-16-2008, 12:41 AM   #25
Fidelity101
Reliable Source
Originally Posted by NoDOHC View Post
I use the Allen head screws from fastenal myself. (I do have access to an impact screwdriver, but it only rings the bolts off in the hub and you have to clock the rotor differently next time.).
I got mine from sears for about 10 or 20 dollars with a couple different bit attachments.
I used to hate allen head and torx bits but I own an audi right now and the VW Germans love to use them so I picked up some torx and allen 3/8"s drive socket sets for them, got one new for a decent amount and the the other at a garage sale for 3 dollars!
My Rx-7 Vids
Old 12-20-2008, 11:33 PM   #26
Rotary13B1
Rotary13B1's Avatar
I now have an extra set of front hubs to swap out. Thanks to Hector who was parting out a TII! Just need some new bearings from Mazdatrix next week and we'll see if I get rid of this noise.
Old 01-02-2009, 01:36 AM   #27
Boostmaniac
Originally Posted by Fidelity101 View Post
sounds like an endlink or sway bar bushing, check to see if you can giggle it, its the sway bar has play around the bushing it will move and clunk when braking since the inertia "pushes" it forward towards the metal bushing holder thingy.
+1
