Old 08-26-2008, 10:55 PM   #1
Eatmyclutch
business as usual
Eatmyclutch's Avatar
Eatmyclutch is an unknown quantity at this point
Default White smoke at start up?
White smoke comes out from the tailpipe when starting up cold. I'm suspecting some kind of leak. I sorta want to keep this car, but at the same time keep driving it for school. Should I be worried about the white smoke?
Bitch
Eatmyclutch is offline   Reply With Quote
Old 08-26-2008, 11:23 PM   #2
rotarycrew
FB connaisseur
rotarycrew is on a distinguished road
Default
sounds like an oil control ring problem. when they start to go it will only be on cold/first starts that they smoke, but i've run motors for a year+ without it getting much worse.
try some lucasoil oil stabilizer on your next change. does wonders for me.
1983 GSL -nitrated plates, -SE housings, RX-8 E-shaft, REPU rotors, alum. flywheel, weber 45 DCOE
1983 GS -S4 13b swap. 60k miles, konig rewinds
1983 Limited-12a street port, 84-85 GSL rear end FOR SALE
1981 GSL - Minnesota mike built Street port 12a with solid corner seals , TO4B turbo, MSD 6A, E-fan, GC coilovers, tokico illuminas, RE-speed strut bar, corbeau seats, simpson 5pt. harness, Kosie K1 15x7's, falken 205/50's, sevens only watts link, 11psi
1981 S - bone stock, 47k miles
rotarycrew is offline   Reply With Quote
Old 08-27-2008, 09:43 AM   #3
Kentetsu
Kentetsu's Avatar
Default
White smoke would more likely be caused by a coolant leak. Probably the two O-rings between the intake manifold and the motor.
Old 08-27-2008, 10:04 AM   #4
Default
Ha???
Old 08-27-2008, 12:09 PM   #5
rotarycrew
FB connaisseur
Default
that may be it too, get a smell of the smoke.
does it smell sweet?
Old 08-27-2008, 02:52 PM   #6
Eatmyclutch
business as usual
Default
It smells like...gasoline...
I also didn't mention this only happened after I recently did an oil change. And the car has a straight pipe welded on.
Bitch
Old 08-27-2008, 03:05 PM   #7
PercentSevenC
Custom User Title
PercentSevenC's Avatar
Default
Sounds like some slight flooding.
Old 08-27-2008, 04:07 PM   #8
Kentetsu
Kentetsu's Avatar
Default
Make sure that your oil level is not too high. This will force oil into the combustion parts, and can also blow out your oil control rings...
Old 08-28-2008, 09:10 PM   #9
Eatmyclutch
business as usual
Default
^^^I'll check my oil level.
Never really had a trouble starting up my car, though I always have to open throttle twice before starting the car.
Bitch
Ad Management by RedTyger
