		#16 |
				Rep Power: 10 ![]()  |
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
		#17 | |
				Rep Power: 18 ![]()  |
 I was under the impression that you had disassembled many engines..... Certainly you should have observed what is depicted below. On the left side you see the wear from driven side seals... on the right observe that there is a ghost of wear ..... no wear whatsoever. Barry
		#18 |
			This is for the guys building their own engines.
	An engine built anywhere in the world will be capable of making approximately the same power if the builder uses good tolerances and has a close attention to detail. This includes engines built by Jonathan, Carlos, Alex, Tom, Brian, Howard, Peter and you Ted....(if you don't see your name I can add it!) There should be no hero worship for anyone special. Forget the hype. Your simple practice should be... 1- make the best possible sealing points... hence the zero-clearance side seals. 2- give the apex seals a flat surface to run-on using something like my sparkplug area cooling mod. 3- Make the AFR's spot-on with help from something like my free Excel AFR Corrections Program or any other autocorrect system. 4- And probably the toughest... center the combustion peak-pressure around 45 degrees atdc. This is where most people fall short... they go for what is called a safe ignition map. If you follow these simple ideas you will have the highest horsepower possible at what ever boost you run, even NA.  |
		#19 | |
 Make sure its not too lean/rich under boost? all parts of the map?  |
		#20 | |
				Rep Power: 19 ![]()  |
 My conclusions are with discussions with someone with a Masters degree in Mechanical Engineering. We blew up a 13B-REW with no turbo (long story) that only managed to put down 130 - 160hp at the wheels on a DynoJet. The engine was running milled 3mm rotors with 3mm apex seals. HOW DO YOU BLOW UP SOMETHING LIKE THAT? The apex seals did not have chipped corners like most of your failed apex seals. (You did tear down enough engines to observe this, right?) The apex seals were cracked straight down the center - height-wise, of course. I have never seen apex seal failure like this except for this one particular incident. The mechanical engineer stated that this failure was a consistent with a harmonic oscillation failure of that type of material. Why am I talking about apex seals when you're taking about side seals and corners seals? You're smart enough to make that connection, right? Oh, and just to back that up... It's been documented by Mazda in a Mazda technical review used as reference for an SAE paper. You're smart enough to go look that up too, right? So, you posted a pic of just about 3 engine's worth of corner seals... How about the other thousand you've come across in your experience? Are you going to state that all the other thousands of corner seals look exactly like the ones in your pic? -Ted  |
		#21 | |
 1) Strap car on dyno 2) Adjust fuel maps 3) Adjust ignition timing maps 4) Go back to #2 and #3 until you're satified This is how I tune my cars for highest horsepower, even NA... Oh, here's a secret: this works for piston engines too... -Ted  |
		#22 |
			Barry, could you elaborate on #4
		#23 |
			 sumdumguy
				Rep Power: 0 ![]()  |
			Aiming for a certain peak chamber pressure vs a given crank angle is fine in theory as most people don't have access to in-cylinder pressure monitoring so its kind of a moot point.  In practice, OEM level calibration involves monitoring the crank angle at which 50% of the combustion charge has been consumed.  The optimal point for CA50 has a 2-3 degree range for any engine, whereas peak cylinder pressure can be deemed "optimal" for a range more than twice that.
	HKS T04Z Bridgeport FD3S  |
		#24 | |
 knonfs, This is what the Excel program looks like. send me a PM and with your email and I can send you a copy. Most people don't understand the importance of an ideal mixture and it's to improvement to the burn rate. ![]() Then on the second folder you take your corrected base map and check it any anomalies. Barry
		#25 | |
 Ted... my guess would have been that there was an interference fit in the freshly milled 3mm slots causing the seal bind when heated. That combined with the infamous peaks caused by the hot spark plug area caused the seal to break in the center. Maybe we could add a #5... when installing all seals make sure that there is absolutely no interference and that the seals spring freely (per the manual). By the way Ted if you have a reference please post it! It will only help the forum. I also noticed that you have not provided any pictures of double worn corner seals. I actually have some but they are ones that I reversed from the last rebuild. To be fair to your thought process... I might theorize that possibly on very hard decel... like at an autox that the seals might be slung forward... but I have not seem any evidence of it. Barry
		#26 | |
 Actually that is the approach that I have been working on. The TFX program also does Fraction Burn and Combustion Rate. Anything that we can do to increase burn rate is beneficial.... One thing that can be done without internal mods (hint) for instance would be experimenting with ignition split and it's effect on burn rate. The saw tooth angle of burning gases and the fraction burn shown below have been used to make definite increases. Barry
		#27 |
			Brian,
	This screenshot is a little hard to make out but it shows that the closer to 45 degrees (in the 5000 to 8000 rpm range) the more peak pressure is made. Notice that each ignition event is different and that the best pressure point can be determined comparing pressure to degrees for peak. Location is the on the bottom chart and in this example we would add degrees of advance as noted then retest. Barry
		#28 | |
				Rep Power: 17 ![]()  |
			Happy Bday the other day Barry.
		#29 |
			I'm a bit sceptical about side seal vibration causing apex seal failure, the pressure differential across the long sides combined with deposits would mean a massive frictional force to overcome sliding back and forth in the side seal grooves, with a minuscule area at each end to provide motive force via gas pressures and very small distance for the seal to build up momentum.
			Thanks for your continued input Barry. Edit: couldn't let this go, and wanted to give a basic explanation for those playing at home. The only way motion of a rotor could push/turn a side seal "backwards" (remembering that the oil seals have directional springs as well) was if you had entirely different e-shaft/seal/rotor design (leaving large dead zones on the sides of the rotors) which allowed the side/corner seals on one side of the rotor to be inside the tooth contact radius of the rotor gear. Not practical or desirable. You can see this simply for yourself by drawing a rotor and stat gear and taking a radius from the point of tooth contact (the stationary point and centre of motion at any time) to anywhere on the rotor, only points lying inside the rotor gear can have a back/forth motion relative to the side plate (through an engine cycle). Even then it would only present a problem if the majority of an independently moving seal part was inside an arc of radius equal to teh gear radius from the tooth contact. That is you could have an engine design with circular oil control seals inside the rotor gear radius (on the off-gear side of the rotor) with the same directional spring design as ours without a problem. Last edited by Slides; 03-23-2016 at 09:46 AM.  |
		#30 |
	Compare the above Fraction Burn and Combustion Rate rate to the result achieved in this much later experiment. You can see the dates of each test in the top left corner. This total increase happens by many very slight incremental improvements. Barry
