Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 11-04-2015, 01:14 AM   #286
RICE RACING
Don Mega
RICE RACING's Avatar
Originally Posted by silverfdturbo6port View Post
Loving my cop setup! My bosch timing light fits on the sparkplug perfectly without removing coil packs
sweet
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 11-04-2015, 04:31 AM   #287
RICE RACING
Don Mega
You got my brain thinking for the M@W ones I will supply one extra spark/coil boot which is cut down on the end to allow that as a simple easy way to check the timing once done put back the normal RED full length boot !
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 11-05-2015, 12:30 PM   #288
silverfdturbo6port
500hp club
silverfdturbo6port's Avatar
silverfdturbo6port is on a distinguished road
I am running a 20b. I cannot get it on the rear rotor plugs but can on the front rotor and middle.
500hp AEM EMS RotaryAutomotive street ported Aviation sealed 13b-rew
20B 20BEEST FD
23A 4 rotor Long gone
72 rx3 drag machine
silverfdturbo6port is offline   Reply With Quote
Old 03-04-2017, 09:58 AM   #289
Pantera EFI
Pantera EFI is on a distinguished road
Secondary Resistance Coil/Plug
Hi Peter, as you know, ARC Duration (your correct art of Spark Duration Measurement @ 380us) states a GOOD quality of current flow, there is a requirement of the Spark Instant/Length with respect to rotor position.
Your current design has NO resistance between the coil/plug.
The addition of a resistor there WILL increase Arc Duration, I good thing for CDI style ignition.
Would it be possible to add a small resistor inline ?
I truly would like you to achieve best performance from the IGN-1CD (early) coil.
Lance
Pantera EFI is offline   Reply With Quote
Old 03-04-2017, 12:21 PM   #290
chibikougan
chibikougan's Avatar
Lance
E-mail his website he doesn't come around here anymore.
Old 09-14-2017, 09:58 AM   #291
Pantera EFI
BAS Hybrid = 6.5 KW
Hi ALL, I am here to be of help, I see little interest here in the Spark Duration requirement.
This requirement is stated by Ricardo = 30-36 degrees of crankshaft rotation.
I believe they have not tested the Rotary.
This application is one of TWO plugs WITH offset firing of each plug.
Thus MORE important with the Rotary, the Arc Duration.
Any Comments ?
Lance, BTW my Alternator is up to eight HP output.
