Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 03-18-2015, 01:08 PM   #226
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
Lance, if the boot is not able to reach down to the metal of the plug, what is the best way of trying to contain the energy?
Slightly excessive amount of die electric grease, what let irons are there...
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 03-22-2015, 09:45 AM   #227
Pantera EFI
Pantera EFI is on a distinguished road
Spark Plug Boot Design
FIRST, my data is MOST OFTEN observed, tested, retested, by the use of my CO-2 Spark Plug pressure chamber firing bench.
This allows for ACTUAL running engine test conditions without damage to the engine.
I have NEVER tested a "dual" boot design. (two boots connected at a parting line)
MY reason is the development of the FireCore 50/250 8.5mm spark plug wire showed HV leaks with others 10mm wire.
What was found: When the insulator diameter was increased from 8mm-10mm, a greater chance of a "pin-hole" size hole was present.
ALL who produce the silicon jacket over the wire conductor have the same problem, its just that the 10mm size allows for the pin hole to be more common.
This "pin-hole" allows the HV to leak out into the air with lower energy passed to the end of the wire.
The WITNESSED observation is seen as a Corona on the outside of the wire.
I should add that my tests where with the use of the IGN-1A coil@400psi. of CO-2.
Reason would state ANY tear, pinhole, cut, "dual-boot" design would cause a HV leak.
Lance
Pantera EFI is offline   Reply With Quote
Old 03-22-2015, 12:20 PM   #228
chibikougan
chibikougan's Avatar
Unless you use a simple amount you would always use of Dielectric or Moly compound. Like you would on any ignition system. Especially I High Performance Ignition..
Use common SNES and you will have no problems.
You forced conditions with an airgap if the airgap is sealed it will not happen correct?
Old 03-22-2015, 05:54 PM   #229
Pantera EFI
Pressure Test of Plug Boot
Correct ? : UNKNOWN
One method, my method, would be to do the test using my CO-2 Chamber.
Would you be able to set the parameters for YOUR test ?
Lance
Old 03-22-2015, 08:19 PM   #230
chibikougan
Its as simple as driving and inspecting the ignition system for Carbon Tracking.
It is very simple to see and to fix the issue. I think I read it in a book from the 50s.
Part of proper regular maintenance.
Old 03-23-2015, 08:49 AM   #231
infernosg
IT'S ALIVE!
infernosg's Avatar
So... any news on the ETA of these? Anxiously waiting as I HATE my current lead configuration!
Old 03-23-2015, 08:52 AM   #232
FC Zach
FC Zach's Avatar
Yep, same here. . .
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-23-2015, 09:27 AM   #233
RICE RACING
Don Mega
RICE RACING's Avatar
Yes I know........
Had a slight delay, have been doing heat treatment of springs (job in itself) as I do all of them myself.
Hoping this time next week I'll smash up a completed assembled IGN-1A unit and for those who have asked me for COP Adaptors and complete units will then take an order and get there items made.
To make them after the first runs (which I am testing) is pretty straight forward process, hopefully more speedy.
I appreciate your patience. I am as keen as all of you!
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-23-2015, 09:45 AM   #234
Pantera EFI
Engine Miss-Fire Detection
The "frankenstein" effect (Carbon Tracking) WILL cause miss-fire which is VERY DANGEROUS to ANY engine.
Constant engine miss-fire causes the "trace" of a conduction path to be easily observed after MANY firings creating the ground circuit destroying the plug boot.
Many times this was the cause of a "blown-up" engine.
WE see the result of miss-fire in the GUI of my ECU-882C after counting the acceleration rate of my 60-2 crankshaft TW.
This is at the first miss-fire hopefully before engine damage can occur.
We have used this method for OVER THIRTY years, as due all OEM's from 2006 on as the patent expired, its the law.
MY hope for those users here that may fit my coils is NOT to explode their engine.
Thus my offer stands, I will gladly test a boot/wire/etc. in my CO-2 chamber without damage to a running engine.
Lance
Old 03-23-2015, 12:26 PM   #235
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Lance
What coils are those Lance?
Perhaps start a different thread where you can go deep in the weeds on this subject (as you're obviously passionate about it) without necessarily derailing the current thread in the process.
Cheers,
Levi
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-23-2015, 09:19 PM   #236
Pantera EFI
IGN-1A Coil Boot & Bracket Design
Hi Levi, THIS thread is about Peters coil brackets AND boots for the IGN-1 coil family.
The brackets he machines look to be fine !
HOW am I "in the weeds" ?
Lance
Old 03-24-2015, 07:31 AM   #237
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
Lance
Your initial concern, that Peters COP adapter didn't form fit to isolate the steel tip from the insulator, leaving an air gap has been addressed by Peter. Since then just about every post of yours so far has harped on YOUR CO2 chamber, YOUR extensive testing, and/or YOUR coils.
Your posts have left the original subject of this thread and are meandering over to your own subject. This is not necessarily a bad thing, but I think your subjects warrant their own thread instead of piggybacking on Peters thread.
That is how you're wandering "in the weeds"
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 03-26-2015, 07:04 PM   #238
RICE RACING
Don Mega
ok I have all parts finished, will take some pics later on today my time, busy with seals that have to be sent to customers so this will have to come second.
*they look great* and work nice
later today/early tomorrow will get in touch with customers who have emailed me about various systems and parts to organize their items, thanks.
Peter
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-26-2015, 11:29 PM   #239
RICE RACING
Don Mega
your mumma
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-27-2015, 12:40 AM   #240
FC Zach
FC Zach's Avatar
Stuff looks great! now. . .
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
