Old 01-18-2015, 08:40 PM   #1
fc7even
fc7even's Avatar
fc7even is on a distinguished road
custom stainless intake
My custom stainless lobster back N/A intake
fc7even is offline   Reply With Quote
Old 01-18-2015, 10:24 PM   #2
RICE RACING
Don Mega
RICE RACING's Avatar
very nice welding, great work.
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-19-2015, 09:47 AM   #3
WankelsRevenge
WankelsRevenge's Avatar
I would love one of these, but fiberglass wrapped to help keep intake temps down.
Summary of this thread:
Old 01-19-2015, 12:11 PM   #4
fc7even
fc7even's Avatar
I can sell you this one if your interested? All i have to do is weld the flange on yet. Its cut already just need to weld it on
Old 01-19-2015, 12:36 PM   #5
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
I hate to point this out, as you've done so much nice work on it, but how do you intend to compensate for engine movement? Even with solid motor mounts there is a little bit of movement.
Old 01-19-2015, 03:01 PM   #6
fc7even
fc7even's Avatar
Well once it bolts up to the throttle body itll sit there like the stock intake and i have a spring mount that will support it close to the maf. So should be no problem
Old 01-19-2015, 05:41 PM   #7
+1
I'm sorry, but having that long, honkin' thing hanging off the TB is still mass dealing with vibration - i.e. physics.
Even if you "spring mount" the AFM, that's even more mass...
Also, stainless steel has this nasty habit of soaking heat.
That duct is hanging over the exhaust exit out of the engine.
There's a reason why Mazda designed it as a rubber flex unit.
If they didn't need have to worry about flex and vibration, a plastic unit would've been lighter and cheaper to install.
I agree that your welding skills are top-notch, but I question the practicality of this application?
Old 01-19-2015, 09:52 PM   #8
fc7even
fc7even's Avatar
If i was using the car more than just weekend cruising id be mor concerned about it. If it gets to hot ill ceramic coat it like i did all my intake manifolds
Old 01-20-2015, 10:41 AM   #9
Pete_89T2
Pete_89T2's Avatar
+1
+2, agree with all that Ted & Gunny stated above. WRT the vibration issue, another thing to consider is that your design will effectively transfer engine vibes directly to the AFM, which most likely will cause your car to idle/run like crap. Reason being is the AFM uses a spring loaded opening (flapper door on S4, cone on S5) to measure airflow. Add vibes (or fail to effectively dampen vibes) to such a design and you can guess what happens to the accuracy of the airflow measurement - it will jitter. Since the AFM is the primary sensor used by the FC ECU to control fuel, measurement jitter is very likely to bugger up your idle/running performance.
Old 01-20-2015, 10:40 PM   #10
fc7even
fc7even's Avatar
Meh we will see. Worth a try
Old 01-20-2015, 10:48 PM   #11
GySgtFrank
GySgtFrank's Avatar
Give it a shot. It seems I've spent at least half my time redoing stuff that didn't quite work out the way I had envisioned on my own project. It didn't work, but it was always instructive.
Old 01-22-2015, 08:41 PM   #12
fc7even
fc7even's Avatar
Heres a picture of it sittin by itself. Tacked the flange on today
Old 01-23-2015, 10:47 PM   #13
sen2two
KTEC
sen2two's Avatar
Seriously. Worrying about intake vibration? It's just an intake tube... I seen many FC's with zip tied flow meters and cobbled together eBay piping intakes.
Nice work man. I hate cutting stainless so i know some dedication went into this.
what I have:
What I had:
Old 01-24-2015, 03:44 PM   #14
fc7even
fc7even's Avatar
^ haha thanks man. I completely agree. I know mazda took that into account when engineering the maf
Old 01-24-2015, 08:30 PM   #15
You should go look up the term: "work hardening"
Vibration (to the AFM) is not what I would primarily worry about.
I would worry that it would crack...
Sure, FC owners are cheap and usually on the young (read: kids) side.
The car might run like shit, but most of these types of owners are just happy to drive down the road and back...
Sadly, having the car run at it's best is not something they can afford to do.
So, I don't see what your point is...?
I even went to compliment his work too...
With this kinda skills, I would suggest looking at other, more better applications of such skills.
Exhaust headers would be an easy example.
As you have already pointed out, FC owners are cheap asses.
The OP mentioned possibly offering this type of product for sale?
Unless priced ridiculously low (like under $20), I doubt it would sell to maybe a select few who wants to own something different without flinching at the price tag.
We're just offering constructive criticism...
