Old 01-09-2015, 05:01 PM   #1
fc7even
fc7even's Avatar
fc7even is on a distinguished road
My "in frame" rebuild
Hey guys, beein workin on my car for 3 years now and its been very slow, but dont mind. Doin it right. Bought the car with my brother in law for cheap cuz it had a short and it kept blowin the egi fuse. But work ive done so far is fux alot of rust. When i got the car it had quite a bit of rust around the wheel wells. Cut that out and welded new pieces in. (Welder by trade) iv got new RB sway bars and adjustable links all around. I deleted OMP and got RTEK 2.1, got a new d.s door cuz it had a huge rust hole through it and the putZ filled it with tin foil. New mouldings all the way around, got the rims powder coated black, all the intake manifols ceramic coated, ripped the exhaust off and making a custom stainless steel header and single 3" exhaust. Im currently working on the exhaust. Hand cut the flange already out of 3/8" 304 ss. Iv also made a custom ss lobster back intake that utilizes the stock maf sensor. If i could find a way to delete the maf i would and run the intake filter farther forward. Im also planning on making a custom under tray for it. Also got new atkins 5/6th port actuators and replaces all the gaskets i could with oem gaskets.
I recently bought a mac tools paint gun so once i fix all the rust and i put the motor back together i will be painting it also. Painted a few cars in my days.
its a slow build but love it. Have a few parts waiting to be put on, stainless clutch and brake lines, toe eliminators and hawk brake pads.
My brother in law got me into rotaries as he has an FD and doin a single turbo street port and just last year my father in law bought a 1973 mazda RX3
File Type: jpg ATT_1417557965417_ATT_1416348193497_20141115_184334.jpg (117.8 KB, 38 views)
fc7even is offline   Reply With Quote
Old 01-09-2015, 06:56 PM   #2
fc7even
fc7even's Avatar
Fd and the RX3
Old 01-22-2015, 10:17 PM   #3
fc7even
fc7even's Avatar
The intake
Old 02-01-2015, 02:04 PM   #4
fc7even
fc7even's Avatar
So yesterday my brother inlaw and me started installing the toe eliminator when we got a little carried away. Ended up dropping the rear sub frame and decided to change all the bushings and get everything sandblasted and painted.
I have been searching and cant find nice poly bushings, will we have to go for oem on the sub frame?
Also have some Tein springs waiting for us and a camber adjuster. Need to get some new shocks and brakes rotors. Some stop tech brakes. Already have all stainless brake lines
Old 02-02-2015, 08:09 AM   #5
infernosg
IT'S ALIVE!
infernosg's Avatar
A company called MMR used to make solid (delrin) subframe-to-body bushings. Other than that I'm not aware of any aftermarket options. As far as I know there isn't even a "Mazdaspeed" (i.e. harder rubber) option so stock is the only option. The bushings aren't that complicated so one with access to certain tools could make their own polyurethane or whatever material bushings.
Old 02-02-2015, 08:24 AM   #6
Pete_89T2
Pete_89T2's Avatar
Last time I checked Racing Beat's website, they listed the Mazdaspeed rubber versions of those bushings, which are supposedly 40% stiffer than stock. Not sure if they are still available though.
Old 02-07-2015, 01:52 PM   #7
fc7even
fc7even's Avatar
Thanks guys. Ill check that out. Today i started my merge collector for my header
Old 02-20-2015, 07:07 PM   #8
fc7even
fc7even's Avatar
Brough all my rear sub frame parts to get sand blasted and eurathane coated. Also built a stainless cone to run off my merge collector so i can run my single 3" exhaust. Also recieved my springs, camber adjuster and fuel rail blank to make my custom fuel railes.
Old 02-23-2015, 08:00 PM   #9
fc7even
fc7even's Avatar
Back from paint. Got the urethane coated
Old 02-23-2015, 08:51 PM   #10
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
looking good.
Old 02-28-2015, 02:27 PM   #11
fc7even
fc7even's Avatar
Got this all tacked up today
Old 05-16-2015, 08:39 PM   #12
fc7even
fc7even's Avatar
Well after a long time comin iv finally built my stainless header. It came out verynice. Just gotta backpurge and welder out
Old 05-17-2015, 10:11 PM   #13
mattallac
mattallac's Avatar
mattallac is on a distinguished road
Looks great ,I am also making a header for my rx3 right now (in stainless ) what a pain in the ass . Looks clean
mattallac is offline   Reply With Quote
Old 05-18-2015, 12:08 PM   #14
fc7even
fc7even's Avatar
Thanks man. Yeah i love workin with stainless. I want to start my own company doin custom fabrication and manifols
Old 10-15-2015, 08:21 PM   #15
fc7even
fc7even's Avatar
Finally got my header and my intake IMG_20151013_205724_wm.jpgall welded up.
