Go Back   Rotary Car Club > Vendors and Group Buys > Group Buys
Old 01-05-2015, 11:23 AM   #31
I wouldn't expect you to change the design, and I'm not sure how you'd change it to fit any better behind the AC and PS with as compact as it is already, but that's cool if you do and you can lol.
Old 01-05-2015, 02:38 PM   #32
RICE RACING
Don Mega
RICE RACING's Avatar
COP Adaptor is finished with insulation rubber plug and removable cover !
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-05-2015, 09:24 PM   #33
RICE RACING
Don Mega
Refined cover plate
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-05-2015, 10:50 PM   #34
RICE RACING
Don Mega
Pretty much over this now
Shit is optimized as much as I can do it, without going mental in the process!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 12:14 AM   #35
RICE RACING
Don Mega
Smashed up a gay arsed video of it ..................
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 05:02 AM   #36
RICE RACING
Don Mega
MOTHER OF GOD!
The COP adaptors are fully done! each end is sealed with O'Ring and all holes, edges, bores etc all done to within a fraction of a millimeter, not possible to make it any more compact or precise
So much work but glad that element is over!
Till some of you get back to me and force me to redesign mounts LOL.
Had a drag person today ask me to do set up for 20B and custom coils, I almost had a stroke so much more work hahaha.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 07:11 AM   #37
RICE RACING
Don Mega
Fuel Injector O-Ring for coil end, fits like a finger in a bum. Totally sealed.
The spark plug end will have 2 O-rings using the factory ribs in counter bore, again tip top.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 11:51 AM   #38
neit_jnf
Boricua!
neit_jnf is on a distinguished road
awesome! I've been waiting on this!
I may have missed it but how do you account for varying sparkplugs people use these days? Or will these work only with certain recommended plugs?
Will these fit with P/S, A/C, etc on a LHD car? Thanks!
neit_jnf is offline   Reply With Quote
Old 01-06-2015, 01:49 PM   #39
RICE RACING
Don Mega
Designed for racing spec purpose only
R7420 spark plugs and older platinum/platinum plugs versions.
I have not validated it but will check plug length of stock type plugs.
Other types of plugs (cheap shit versions) NO!
IF you run these then you are not the kind of person who would pay for my quality items anyway so it was never designed to suit that market.
Other aspects a few people are checking out RE: PS and AC etc
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 01:57 PM   #40
I think this is the fastest I've ever seen anything be developed LOL. Well done, well done. I'm eager for people to measure for the PS and AC, and I might see if my buddy can measure between the engine and pump on my car. Or I might just get one regardless, knowing I can easily resell it if it doesn't fit my setup lol.
Old 01-06-2015, 02:07 PM   #41
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
plugs.
So these would work with the BUR#EQ(P) plugs then, correct?
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 01-06-2015, 02:20 PM   #42
RICE RACING
Don Mega
From my memory they are the same dimension so yes, but will validate that this morning my time and post back.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 01-06-2015, 02:42 PM   #43
Just move the damn pump!
Just run the 7420's dude.... the reason I generally rec AGAINST colder plugs is because the ign system isn't up to snuff to properly fire the plugs. Change to colder shitty 6750 I think???? and need to "retune" the car because the AFR's are all over the place, then as you're pulling fuel out you see the EGT's go up... fuck that noise......
These coils I don't see as having a problem.
Old 01-06-2015, 02:47 PM   #44
But I don't wanna! lol I had the mounting bracket welded to the frame with the bolts sticking out, and I don't want to move the pump again and just leave all that exposed. If I could remove the bracket and make it look good like the stock frame again, I'd seriously think about it.
Old 01-06-2015, 05:03 PM   #45
RICE RACING
Don Mega
OK!
I did a major redesign config, this is the best I can package it for OEM use.
Tell me what you think? its under 14mm past the front edge of the rotor housing now!
*New engine bracket mount
*New coil spacer mounts
*Re-Oriented COP adaptors
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
