Old 12-30-2014, 09:43 PM   #1
stuwk
stuwk is on a distinguished road
Rx7 FC Adjustable Rear Toe Links
Rx7 FC Rear Toe Links are now for sale! $175 + Shipping!
The Hex is adjustable with a 1" wrench, and the locking nuts are a
1 1/8th" wrench.
They are a direct fit and allow for standalone rear toe adjustment.
Pm me for info!
stuwk is offline   Reply With Quote
Old 12-31-2014, 02:05 PM   #2
chibikougan
chibikougan's Avatar
What is done to the tapered holes in the subframe and control arms?
Do they travel freely up and down?
Can you get a picture with the center propped up and let the control arms sag as far as they can?
Old 12-31-2014, 03:35 PM   #3
stuwk
Oh man, I put this in all kinds of the wrong section.
Anyways the taper that you see on the stock links is simply a location finder because the stock toe link studs are significantly smaller than the actual hole. Only the first 3/8th" of the hole is tapered, the rest is a regular non tapered hole. The bolts used in these adjustable links fits and fills the regular non tapered part of the hole allowing for a tight fit and no movement. These has been used on several cars including an 8.8 swapped LS powered FC, which is the sub-frame in the picture.
I will see if I can get a picture like that but my set is back in a driving car.
Old 12-31-2014, 04:19 PM   #4
chibikougan
The holes are tapered I had them machined for inserts. Yeah that's all I needed to hear thanks anyway.
