Old 12-03-2014, 12:52 AM   #271
RICE RACING
Don Mega
RICE RACING's Avatar
Some updates happening ....
Link > http://www.riceracing.com.au/apex-seals.htm
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-03-2014, 10:14 AM   #272
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
You must love your seafood mate.. Those scallops
'94 Touring - Cursed
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 12-03-2014, 10:39 AM   #273
C. Ludwig
Rotary Masochist
http://www.lms-efi.com
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 12-03-2014, 10:58 AM   #274
^Damn those look good haha. Sucks being deployed and getting shit food lol.
Those rotors look delicious also. I forget, are the scallops just for weight savings or do they benefit rotation in some other way? Also, the attachment on the side of the housing by the spark plug holes...is that to flow more coolant where it's hotter and those are banjo bolts? That's pretty trick. How does it attach at the blue fitting? Is that a banjo bolt also?
Old 12-03-2014, 01:02 PM   #275
Fendamonky
Get off my lawn!!!
Fendamonky's Avatar
I believe scalloping the rotors like that is done to extend how long the intake is open for.
'96 NA Miata
'14 Mazda3 Hatch
'14 Aprilia RSV4 R
Old 12-03-2014, 01:34 PM   #276
C. Ludwig
Rotary Masochist
More duration without overlap.
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 12-03-2014, 04:33 PM   #277
RICE RACING
Don Mega
On the RICE RACING rotors:
* primary reason is to reduce the compression ratio to allow highest power with reliable operation on any basic petrol
* gives overlap earliest possible opening and latest closing on RICE RACING street port, also improves 'flow'
* CR benefits listed below
On the plug cooling:
Its banjo style into rotor housing, and AN fitting inlet, in pic is just a block off cap.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-03-2014, 04:49 PM   #278
RICE RACING
Don Mega
As stated its mostly done to allow the correct engine compression ratio #1
On the overlap aspect:
My engines actually have quite allot, not as much as a bridge or semi pp, but enough (maximum possible on a street port) to allow high Ve at high rpm thereby improving power output and rev range. Its the best balance for an engine running on the street yields highest average power curve when matched correctly in other areas.
You can tell this when you look at equalized engines such as in my power at 1 bar NA thread. I have a very extensive list on this (far bigger than what I put in that thread),
This combo pictured with an EFR9180H and Cosmo inlet manifold on RICE RACING street port is well over 260bhp @ 1 bar (N/A) and it works to 4 bar reliably.... which is a little bit of power
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-03-2014, 09:30 PM   #279
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
That scalloped rotor is the TITS!!!
On another note, Peter, it made my day to see the banana from the rejected cartoons at the top of your webpage...
I laughed for a good bit about that...
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 12-04-2014, 09:03 AM   #280
C. Ludwig
Rotary Masochist
I didn't take into account scallops on the leading edge of the rotors. I've only ever used them on the trailing edge. So, yes, you will create overlap. Good looking work!
chris@lms-efi.com
502-515-7482
Facebook @LMS-EFI
Old 12-04-2014, 05:19 PM   #281
RICE RACING
Don Mega
Thanks,
I will also have up pics of my own manufactured Apex Seals soon too
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-04-2014, 08:13 PM   #282
Prodigy
Prodigy's Avatar
Did you modify the size/shape of the tub on the rotor to lower compression? Looks like you increased the area and depth of it...
J.
Old 12-04-2014, 08:29 PM   #283
RICE RACING
Don Mega
J.
YES, it is the only way to cure the FUCKED Mazda casting and equalize the CR on each face, but most importantly to run the correct CR needed for highest power and reliable operation.
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-04-2014, 08:37 PM   #284
RICE RACING
Don Mega
J.
If you look at the old Honda F1 turbo days (running 84% Methyl benzene fuel)
2.5bar (22psi engine) ran 9.5:1 CR
4.0bar (43psi engine) ran 7.4:1 CR
It's all about using the right CR to stay within the effective compression ratio guidelines I posted above in my spreadsheet.
early pump fuel turbo engines ran 6.5:1 CR
Mazda Factory 13B bridge turbo's and the same motors sent to RB ran 7.5:1 CR
Its not Rocket Science, just basic Thermodynamics and laws being respected.
My CR is not openly disclosed but you can guess it's near these correct figures
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 12-05-2014, 03:53 PM   #285
OK thanks!
