Old 04-13-2012, 08:16 AM   #91
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Sephitrask is on a distinguished road
Well only one is leaking right now, but with 100k miles on them i'm replacing the pair.
www.rotarycarclub.com
"The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot."
Sephitrask is offline   Reply With Quote
Old 04-13-2012, 11:47 AM   #92
Are they stock?
I have a complete set of 50K struts with springs, top hats, everything assembled taking up space in my garage
Old 04-13-2012, 12:26 PM   #93
Proxy One
Victory Is Mine
Proxy One's Avatar
Proxy One is on a distinguished road
My To Do list is getting smaller.
Clutch Change to 6 puck Sprung. Release and Pilot Bearing -DONE
Fix a few minor oil leaks - DONE
Change Tranny Fluid over to NEO - DONE
Bleed Clutch with ATE Super Blue - DONE
Still Need to do:
Fix Radio issue with grounding (need tunes on the Gap)
Fix Cigarette Lighter Socket not working
Change intake filter on turbo (its in the mail)
Fix leaking power steering line on reservior, needs new clamp I think.
Change oil
www.dealsgaprotaryrally.com
1994 Rx7 White 2001 RZ GT35R'd
1972 Rx2 Orange Coupe 5spd
2006 STi
1986 Buick GN
Proxy One is offline   Reply With Quote
Old 04-13-2012, 12:27 PM   #94
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Are they stock?
They have s techs on them (that may be another factor besides their age that did it, lol) Plus I need them on tomorrow, since I am working sunday-wednesday, and am not about to drive to Deals gap with a blown shock, seems like a very bad idea. Thanks though, I appreciate it!
Old 04-13-2012, 03:07 PM   #95
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
This weekend I will be doing: a radiator swap, fix exhaust leak, fabricate a heat-shield for the intake, tune, check brakes and everything else, wash the car cause it is dirty!
Procrastination.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 04-13-2012, 08:43 PM   #96
willnordacgreen1211
willnordacgreen1211 is on a distinguished road
almost ready! gotta swap out an axle, and hopefully get my sparco seat installed and im ready to go!
willnordacgreen1211 is offline   Reply With Quote
Old 04-14-2012, 06:19 PM   #97
rgould
Rotary Non-conformist
rgould's Avatar
rgould is on a distinguished road
Wink Our to do list
Our 82 GSL
1) Remove, disassemble, clean, powder coat, and rebuild brakes on all corners. Done
2) Flush brake system. Done
3) Replace rear hatch lift rods. Done
4) Change oil and filter. Done
5) 500 mile shake down. Done
6) Final clean up. To do
Our 93 R1
1) Change oil and filter. Done
2) Flush and change coolant. Done
3) Change spark plugs. Done
4) Add shift light and tach. Done
5) Shake down. To do
rgould is offline   Reply With Quote
Old 04-15-2012, 11:45 AM   #98
N.RotaryTech
Home-brew Rotary
Radiator swap = Done.
Check brakes and everything else = Done.
Tune = Done.
Wash car = Done.
And that how it will roll.
Old 04-15-2012, 03:11 PM   #99
willnordacgreen1211
powertrix coilovers-DONE
carbon fiber trunk and lip spoiler- DONE
new plugs/coils/wires- DONE
new starter-DONE
cobb ap installed and tuned- DONE
replace axle-DONE
air pump delete- DONE
all thats left is align it and wash it!
Old 04-15-2012, 07:03 PM   #100
88turboii
destroy, rebuild, repeat
88turboii's Avatar
i get everything done, and installed 1600's this weekend, but then had a bunch of fuel leaks pop up. hopefully get it fixed by thursday! that and need to change the oil and i should be ready
Old 04-15-2012, 10:16 PM   #101
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
I have the passenger side suspension done, I have to do the shock/endlink for the drivers side on Tuesday when the parts come in then an alignment on Wednesday.... Talk about last minute!!
Old 04-16-2012, 12:05 PM   #102
Rotorypolo
Rotorypolo's Avatar
Rotorypolo is on a distinguished road
To do list on 94 (friend's car)
-remove old engine- tranny, drop in new engine - tranny - done long time ago
-convert old single setup to simplified seq. setup - done
-put in new stock turbos - done
-blew stock twins on dyno ( bad turbo from ebay!) cough cough
-install new GT35R turbo / convert to single, etc etc - done
-install shitty ebay intercooler - done
-dyno tune on shitty chinese IC - done (found exhaust leak and major heat soak)
-install new coilover suspension - done
-install new fuel pump and fix floater - done
-install short shifter - done
-fix exhaust leak- done
-reroute waste gate open dump - done
-install new cat-back exhaust - done
-new 1.06 hot side - done
-new V-mount IC setup - done
-fix minor vacuum leaks - done
-new injector resistors & wiring - done
-a good tuning - done (FINALLY)
-install and wired up new water temp gauge - done
-fix injector leaks - done
-install new front rotors and pads - done
-change plugs - done
-fix broken door locks, handles, etc. - done
-retrofit projector HID headlight - done
relocate battery to rear - done
Still to do list
-install rear rotors and pads
-install alum. AST
-new paint job
-cut stock hood, install hood vents
-install Mazdaspeed GTC front
-install remote entry
-sound system/headunits
-NEVERENDING maintenance, and upgrade
1994 RX-7 PEP - (SOLD)
1993 RX-7 R1 - (under the knife)
1973 RX-3 13b 5 speed (DGRR 2011- 1st in class)
Rotorypolo is offline   Reply With Quote
Old 04-16-2012, 07:47 PM   #103
Sephitrask
BOILED PEANUTS!!!
Sephitrask's Avatar
Still to do list
-install alum. AST
-new paint job
interested in the "cut stock hood install hood vents" part. what vents are you using, and do you have any pictures of your idea?
Old 04-16-2012, 08:25 PM   #104
Rotorypolo
Rotorypolo's Avatar
It is the 9Kracing hood vents
see here
http://www.9kracing.com/new-batch-of...ng-hood-vents/
Here are some pictures i found on the internet of this hood on FD
http://www.rx7club.com/showthread.php?t=843724&page=21
Old 04-17-2012, 02:43 PM   #105
estevan62274
counting down till DGRR
estevan62274 is on a distinguished road
Thumbs up
Alignment..... DONE!
Plugs....... DONE!
Oil change......DONE!
She's ready and I'm so for this years DGRR!
-74 RX-4
-84 REW GSL-SE
Past rides
-05 REW Swapped RX-8
-93 FD base
estevan62274 is offline   Reply With Quote
