|  03-10-2008, 04:04 PM | #1 |
| sa rat rod Join Date: Mar 2008 Location: tewksbury ma
				Rep Power: 18  |
				ball joints help asap.
			hey guys i need some help. i have to replace my ball joints on my 1980. i got new ones shiped to me and i got them today. i know your not spose to reuse the lower control arms. but you are not able to buy new one. on th evil site every one said just add a few tack weld's which will not be a problem for me. how can i get the old ball joints out. i dont think i can do it my self. but what type of place can i go and have them pressed out and the new ones pressed it?
|  03-10-2008, 08:58 PM | #2 |
| RCC Contributor Join Date: Feb 2008 Location: Grand Rapids, Michigan
				Rep Power: 18  |
			I used Autozone's loan a tool program, and borrowed their ball joint press set.  Work carefully, making sure everything is lined up properly, and you might be able to do it.  I had no problem doing mine, and they were tight enough that I didn't have to add welds or anything.  Just make sure that you don't deform the arms when pressing the joints...
|  03-11-2008, 03:54 AM | #3 |
				Rep Power: 18  |
			how does that tool loan program work.
|  03-11-2008, 12:01 PM | #4 |
| Rotary Fanatic Join Date: Feb 2008 Location: AL
				Rep Power: 18  |
			for the tool loan program essentially what you are doing is buying whatever tool you are borrowing for a more expensive amount than it usually sells for and then when you return it they return your deposit. it works pretty well. i used it to borrow a tap and die set to fix some fouled up thread on my exhaust studs.
				__________________ 1993 BB RX-7 2005 Black Mazda 6i 1991 Primer Celica GT 1968 Camo Chevy P/U Garfinkle's Airpump Idler Pulley: Keep the stock contact patch on your water pump w/o running Airpump! |
|  03-11-2008, 02:57 PM | #5 |
				Rep Power: 18  |
			i found this a ball joint press from harbor freight for like 30 bucks. i could just sell it on ebay when done.
|  03-11-2008, 06:34 PM | #6 |
				Rep Power: 18  |
			How is that easier than the loan a tool program?
|  03-11-2008, 06:38 PM | #7 | |
| Mod With The Least :P Join Date: Feb 2008 Location: Manchester, TN
				Rep Power: 0  |
			Not sure....Plus harbor freight stuff is usually of questionable quality.
				__________________ Resident Post Whore Polluting the environment one revolution at a time.  www.tennspeed.net Quote:
|  03-11-2008, 07:19 PM | #8 |
				Rep Power: 18  |
			true. wounder if i can do it in the store and not pay any thing lol . iam friendly with a few guy's at the store down the street from my house. also guys can you look at my e-fan thread and tell me what you think. |
|  03-12-2008, 02:19 AM | #9 |
				Rep Power: 18  |
			it can't hurt to try going to the store with the lower control arms and pressing the ball joints out while at the store. i didn't even know the guy at my local store and he asked if i wanted to use the tools in the store.
|  03-13-2008, 08:33 AM | #10 | |
| Big Daddy Join Date: Feb 2008 Location: Rhode Island
				Rep Power: 18  | Quote:
				__________________ Hell hath no fury like a rotor blown. | |
|  03-13-2008, 09:59 AM | #11 |
				Rep Power: 18  |
			in the fsm it says not to reuse the lower control arms . since you not able to buy oem one any more just the racing beat ones. i was told to just put 3 1cm welds on them to make sure they dont come out. i figure by the time iam ready to replace my ball joints again ill drop the money and get the racing beat control arms.
|  04-15-2008, 09:38 PM | #12 | |
| The Newbie Join Date: Apr 2008 Location: Upstate NY
				Rep Power: 0  | Quote:
  Scott
				__________________ 1982 RX7 - 143K (3rd of this gen) 1995 BMW 525 125K | |
|  04-16-2008, 07:56 AM | #13 |
| Talk - Action = Nothing Join Date: Feb 2008
				Rep Power: 18  |
			Its a known deal. The problem is that the control arm material is thin in this area. The operation of pressing them in from the factory expanded a smaller hole to snug them in. The operation of pressing the old joints out usually distorts the metal. New ball joints do not get enough "bite" to stay in since the hole is already expanded from the factory and distorted from you pressing them out. Some aftermarket ball joints have a groove machined into them for a c clip to keep them in. If yours do not you will want a few small tack welds. Mig is the best since you can get in and get out without heating up the ball joint to bad. Tig concentrates to much heat and can burn up all the grease. -billy |
|  04-16-2008, 09:50 AM | #14 |
| Rotary Fanatic Join Date: Feb 2008 Location: Jacksonville, NC
				Rep Power: 18  | |
|  04-20-2008, 08:51 AM | #15 |
				Rep Power: 0  |
			Mazdatrix still sells control arms (oops can I mention their name, oh wait, that is the other board). They are about 150 each. Scott
