Using an Xcessive LIM with 99 or stock twins
Using an Xcessive LIM with 99 or stock twins:
The Xcessive LIM is not a direct replacement for the stock LIM if you plan to continue to use the stock or 99 twins. There are several things that don’t allow them to bolt right up. Here is a list of modifications that need to be made: Oil and Water supply lines need to be bent to clear the front side of the LIM ![]()
![]() 93 RX7 BB (Race Car) 93 RX7 SSM (Soon to be IBM and a daily driver) 05 Silverado Z71 08 Mini Cooper 80 LS RX7 (for sale) Last edited by Chadwick; 04-23-2008 at 01:02 PM. |
I spy somebody has the same pulley kit that I have with the acorn Alt nut...lol...
#3 | |
yeah, I've got the wide belt (both 6 rib) setup. |
Long Time Onlooker
very informative Dan, thanks for the heads up
93 Touring - AD coilovers, BBK, full exhaust, PFS SMIC, PFC |
Thanks a lot, this is going to help greatly.
Viable Fossil
Could you elaborate a little on heating the plastic oil fill neck. Heat-gun I assume. Anything else to it, can it be done on the car? Thanks.
Jim VR R1 FD |
Yes, we used a heat gun. Takes quite a bit of heat to get it to bend, so much so that it will blister the plastic. I would not suggest doing it on the car. It seals with an O-ring, so makes sure you have a new one on hand when you remove it. You could also save yourself the work and buy this: http://mrcmfg.com/catalog/product_in...roducts_id=258
Dan
![]() 93 RX7 BB (Race Car) 93 RX7 SSM (Soon to be IBM and a daily driver) 05 Silverado Z71 08 Mini Cooper 80 LS RX7 (for sale) Last edited by Chadwick; 04-13-2008 at 11:16 PM. |
I had the same clearance issues, but went with ReSpeed filler neck. It clears
#9 | |
By the way, mine came with a longer bolt for the one you show. Dan |
#10 |
Go for it.
The LIM didn't come with a bolt so I had to source my own. |
