Closed Thread
Old 03-28-2011, 11:20 PM   #1
MmSadda
BOOSTED COLON
MmSadda's Avatar
MmSadda is on a distinguished road
Angry Recently rebuilt 2nd gen suddenly won't start - where to begin?
Okay, here's the deal -
I'm driving an S4 (87) n/a, stock for all practical purposes, got about 25k miles on a rebuilt engine, and at the same time got new fuel pump, new injectors, new ignition coils, etc.
I drove the car two days ago, and it ran 100% normal. Tried to start it today, and it'll sit there and crank and crank but won't actually fire up so I think I'm either not getting fuel or not getting a spark.
What's a good starting point as far as things to test?
**I should note, the guy who rebuilt my engine installed a kill switch (pretty sure it's for the fuel injectors, in case the engine floods)
MmSadda is offline
Old 03-29-2011, 06:35 AM   #2
tweiss3
Mazda Lover
tweiss3's Avatar
Did you try "flood" starting it, put the pedal in the floor and crank it? See if it turns over then.
tweiss3 is offline
Old 03-29-2011, 06:50 AM   #3
This does not work for any S4 vehicle.
RETed is offline
Old 03-29-2011, 07:03 AM   #4
tweiss3
Mazda Lover
tweiss3's Avatar
Oops, works on my S5. I forgot. Pull the plugs and crank for 15 seconds, reinstall plugs and see if it starts up.
tweiss3 is offline
Old 03-29-2011, 08:13 AM   #5
Shouldn't the tach 'bounce' if it is getting spark?
I forget.
djmtsu is offline
Old 03-29-2011, 08:27 AM   #6
I forget.
Yes, but that only indicates a specific coil is firing.
vex is offline
Old 03-29-2011, 10:52 AM   #7
RXTASY
idahorotary.com
RXTASY's Avatar
RXTASY is on a distinguished road
Pull the plug wires and put a screw driver to the tip of them and see if there is a spark arcing.
If there is, pull your two leading plugs, and yer EGI fuse and turn it over and blow all the gas out of it. Squirt a little motor oil in there while yer at it.
Try that.
87 TII-E85-600+ RWHP and climbing
Life starts at 2 bar!
Come visit my forum! idahorotary.com
http://idahorotary.com/smf/index.php
RXTASY is offline
Old 03-29-2011, 10:52 AM   #8
MmSadda
BOOSTED COLON
MmSadda's Avatar
Thanks for jumping in here!
What will that do? If it's a cure for flooding, the kill switch works for that. If it's supposed to cute something else, lemme know and I'll try it!
I forget.
My tach 'bounced' all of once in the whole time I was trying... so it does sound like I may not be getting spark. What would I do to test/confirm this?
MmSadda is offline
Old 03-29-2011, 11:05 AM   #9
MmSadda
BOOSTED COLON
MmSadda's Avatar
Try that.
As in, screwdriver in one hand, and one plug wire end in the other, right? how far apart should I hold them?
If there's no spark arcing, that means my trailing coil is not functioning, then, right?
MmSadda is offline
Old 03-29-2011, 11:20 AM   #10
FC Zach
FC Zach's Avatar
I typically just leave a plug in the end of the wire and ground it, have a helping hand to turn it over, and while that is going on you can observe whether or not there is spark. Screwdriver works too, just a little cumbersome to me.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
FC Zach is offline
Old 03-29-2011, 11:58 AM   #11
Redshft
Redshft's Avatar
Redshft is on a distinguished road
This.
But, having been zapped before, I'm now paranoid and I use a set of pliers with an insulated handle to hold the plug by the boot on the wire.
2004 RX8 GT
1986 RX7 Track Car: 13B Bridge Port w/ Renesis Internals and Weber Carb
2003 MazdaSpeed Protege
1988 RX7 Convertible - new project
2004 Impreza and 2003 Legacy wagons for hauling groceries and The Dog
Redshft is offline
Old 03-29-2011, 12:19 PM   #12
FRED
FRED is on a distinguished road
Watch the tach needle while trying to start the engine. IF the needle makes small movements that tells you a lot. It tells you that the ENGINE fuse, both EGI fuse are all good and that the main relay is pulling in.
Engine will not start with a blown EGI fuse(s), engine fuse, period.
IF the needle does make movements try deflooding it by the usual methods. I assume you don't have a blown apex seal when saying this and you have gas in the tank and there is no fuel cut switch in the OFF position.
EDIT: And or ...........put a jumper in the fuel pump check connector and the key put to ON. The fuel pump should be heard running. If not.......too bad, something is amiss.
FRED is offline
Old 03-29-2011, 12:50 PM   #13
My5ABaby
My5ABaby's Avatar
Pulling the fuse does essentially the same thing your fuel cut switch does. Putting oil in the engine helps build compression if it's been flooded.
Community Service Manual
RotorWiki
My5ABaby is offline
Old 03-29-2011, 12:52 PM   #14
MmSadda
BOOSTED COLON
MmSadda's Avatar
I'll check the EGI fuse. -checked and all fuses with EGI in the title are fine.
Tach is making the tiniest of bounces once each time I start the ignition, then nothing.
**engine isn't flooded, there's practically no way an apex seal is blown, etc. - Fred's assumptions are all fair.
MmSadda is offline
Old 03-29-2011, 12:53 PM   #15
MmSadda
BOOSTED COLON
MmSadda's Avatar
Where is the fuel pump check connector? Not coming up with that one easily in the Haynes manual
MmSadda is offline
Closed Thread
