			 Turblown Engineering
				Rep Power: 18 ![]()  |
				Just Shy of 500rwhp
			TD61( GT35R Comp, P trim turbine 1.15 a/r) 22psi
			Small Street Port Inconel Heat shields 3.5" exhaust MSD ignition Greddy FMIC Pulls hard on street, 285s aren't enough...  |
			Alot of work payed off .I guess wider tires are next on the list .
			 Don Mega
			Fuel used? other specs?
			Would love to see a video of (3rd to 4th gear) 60mph to 130mph or 100kmh to 200kmh along with times........
	www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration  |
			109 octane, dual walbros, stock 550s/2200 secondaries, 77 % duty cycle.
	We are reflowing injectors to work out the bugs. I can tell you this it spins the tires @ 80mph in 3rd gear. Will look into getting videos of those times...  |
			 Don Mega
			Good stuff
			![]() We have to start up a list here of cars that do 60mph to 130mph like many other enthusiasts do. Race Logic Performance Box is a cheap way to obtain the data and we can collate a "RCC record list".   http://www.rotarycarclub.com/rotary_...ead.php?t=1263side note: what AFR at 6500rpm and timing? if you care to share?
			www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration Last edited by RICE RACING; 02-17-2011 at 08:09 PM.  |
			Afr was 11.7, timing was really low, around 6-8 degrees. We changed the split then ended up having issues..
		#8 | |
			 Don Mega
 Keep up the good work, I like reading your posts, seeing the pictures and videos
		#9 |
			 Bubble Tech
			what ecu are you running? what did u do to get rid of the coolant buzzer?
		#10 |
			PFC, coolant buzzer is hooked up in that custom thermostat neck...
	Otherwise you can just ground it on the harness.. Funny thing is I tuned another car to 607rwhp the other day, and it made the same torque as this car..  |
