Old 02-16-2011, 11:03 PM   #1
1Revvin7
Turblown Engineering
1Revvin7 is on a distinguished road
Just Shy of 500rwhp
TD61( GT35R Comp, P trim turbine 1.15 a/r) 22psi
Small Street Port
Inconel Heat shields
3.5" exhaust
MSD ignition
Greddy FMIC
Pulls hard on street, 285s aren't enough...
Rx-7 Turbo Kits, Engine Building, and Parts
www.turblown.net
1Revvin7 is offline   Reply With Quote
Old 02-17-2011, 12:06 AM   #2
Garfinkles Motor Works
Alot of work payed off .I guess wider tires are next on the list .
Old 02-17-2011, 12:56 PM   #3
1Revvin7
Sure did!
http://www.youtube.com/watch?v=hHhyIK_uCtc
Old 02-17-2011, 05:14 PM   #4
RICE RACING
Don Mega
RICE RACING's Avatar
Fuel used? other specs?
Would love to see a video of (3rd to 4th gear) 60mph to 130mph or 100kmh to 200kmh along with times........
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-17-2011, 07:49 PM   #5
1Revvin7
109 octane, dual walbros, stock 550s/2200 secondaries, 77 % duty cycle.
We are reflowing injectors to work out the bugs. I can tell you this it spins the tires @ 80mph in 3rd gear. Will look into getting videos of those times...
www.turblown.net
Old 02-17-2011, 08:01 PM   #6
RICE RACING
Don Mega
Good stuff
We have to start up a list here of cars that do 60mph to 130mph like many other enthusiasts do. Race Logic Performance Box is a cheap way to obtain the data and we can collate a "RCC record list". http://www.rotarycarclub.com/rotary_...ead.php?t=1263
side note: what AFR at 6500rpm and timing? if you care to share?
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 02-17-2011, 08:27 PM   #7
1Revvin7
Afr was 11.7, timing was really low, around 6-8 degrees. We changed the split then ended up having issues..
Old 02-17-2011, 08:33 PM   #8
RICE RACING
Don Mega
FYI I generally on a split system don't deviate much from 12 to 8 degree's (at that point) depending on what the engine wants.
Keep up the good work, I like reading your posts, seeing the pictures and videos
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-15-2011, 11:57 PM   #9
muibubbles
Bubble Tech
muibubbles's Avatar
muibubbles is on a distinguished road
what ecu are you running? what did u do to get rid of the coolant buzzer?
Bubble Tech
www.BubbleTech.us
muibubbles is offline   Reply With Quote
Old 03-17-2011, 12:10 AM   #10
1Revvin7
PFC, coolant buzzer is hooked up in that custom thermostat neck...
Otherwise you can just ground it on the harness..
Funny thing is I tuned another car to 607rwhp the other day, and it made the same torque as this car..
