Closed Thread
Old 10-27-2010, 10:34 AM   #16
sv51macross
sv51macross is on a distinguished road
Originally Posted by TS87FC3S View Post
ok so guys i have a question, i hate electrical with a passion so here is my question what am i going to have to do to keep all power windows, lock, sunroof, lights, guages etc all working ? ive tried looking at schematics but all that happens is a major headache
You hate electrical, and yet want to do a non-Honda/Nissan swap?
If looking at wiring diagrams gives you a headache then either buy a Supra or pay someone to do the swap. It's not that bad, the hard part is figuring out where the wires get routed.
1990 Mazda RX-7 NA; Lucy, after the main antagonist from Elfin Lied.
Eventual plans? Something cyberpunk and spicy.
sv51macross is offline
Old 10-27-2010, 10:55 AM   #17
FC Zach
FC Zach's Avatar
All said accessories will work regardless of whats goin on in the engine bay. My old 89 GXL had nothing but the alternator wire and of course the battery connected. (It was carbed BTW)
Edit: The tachometer will need to be connected and that is easy. All FC's have a single wire test connector on the driver side somewhat in-between the starter relay and the Clutch slave cylinder. It is yellow and has a female bullet style connector.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
FC Zach is offline
Old 11-25-2010, 09:15 PM   #18
TS87FC3S
Ask Me About My WANKEL!!!
TS87FC3S's Avatar
TS87FC3S is on a distinguished road
ok sorry havent been able to get to a computer for a bit and just finally got started back on the swap everything is out of the engine bay and starting to figure out wiring.. i hate electrical but i can do it easily and it will all be done im doing the 2j swap into the mk3 next to my rx7 also.. heres a couple pictures and will have more up soon project is starting to get going a little smoother
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline
Old 11-26-2010, 01:39 AM   #19
willnordacgreen1211
willnordacgreen1211 is on a distinguished road
im sure itll be fun when it gets put together... but im really against 2j swapping. more against piston swapping a rotary. either way good luck with the build man!
willnordacgreen1211 is offline
Old 01-11-2011, 01:37 PM   #20
TS87FC3S
TS87FC3S's Avatar
ok so the 2j is being put on hold for right now.. bought another 88 se rx7 to get parts for my car and dd it
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline
Old 04-29-2011, 10:31 AM   #21
ExcessFC
ExcessFC is on a distinguished road
When I fit a 2J, the problem is the deck is about 3/4 of an inch higher than the 1J. This is why I went 1JZ because I did want to keep a sway bar and keep the oilpan out of the rocks, and also keep a stock hood.
The body harness and the engine harness are 2 completely different things in response to your last question.
ExcessFC is offline
Old 05-01-2011, 09:37 PM   #22
TS87FC3S
TS87FC3S's Avatar
Build hit the fan and sold for way more then i had invested, thread can be closed.. DId get a 84 fb keeping 12a in it
1988 Rx7 Se - Sold
1988 Rx7 GXL - Sold
TS87FC3S is offline
Closed Thread
2jz
