Old 10-24-2010, 05:35 PM   #1
hades
Electrical connectors - t-stat housing
the fan switch broke off the engine harness and my fan switch is not is much better condition.
Any where to get replacement connectors-besides ray?
This is going to tear
Last edited by TitaniumTT; 10-25-2010 at 08:07 PM. Reason: You're welcome, Admin at your service
Old 10-24-2010, 05:43 PM   #2
Why not cut the connectors off and crimp on some new ones. Skies the limit but with the amount of A's those draw I would go with some weather-paks or 280 series metri-packs.
Terminal Supply Co or Del-City.net would be the best places, but I believe they have a $25 minimum order. I have seen them @ Napa on occasion.
Old 10-24-2010, 06:53 PM   #3
Ratjar
Ratjar is on a distinguished road
digi-key probably has the plug you want. or just re-crimp new plugs of a different style on. would be pretty easy.
Ratjar is offline   Reply With Quote
Old 10-24-2010, 07:27 PM   #4
hades
sorry - a bit not sober - but how do you change connectors - if they have to fit the sensor?
Old 10-25-2010, 01:22 AM   #5
Garfinkles Motor Works
I use GM weather packs .Just solder wire ,wires to the unit and install a GM connector .Cut the broken connector from the harness and put in the maching GM connector .I keep 1 wire 2 wire 3 wire and 4 wire ones in stock .They make a 6 wire one as well .I buy them by the box and have been useing them for several years.I solder on the wire wires to the sensor and fill the cavity with epoxie .
Old 10-25-2010, 07:18 PM   #6
hades
Thanks,
Rotary Performance gave the same advice. Where do you get your connectors?
also can a mod fix my typo in the title?
Old 10-25-2010, 08:08 PM   #7
There are three places that I use, but I buy in bulk, regardless, I'd stock up. They're great to have around rather than waiting a few days
Waytekwire.com
TerminalSupplyCo.com
DelCity.net
Terminal Supply and DelCity have connector kits, I believe. Watch the A ratings though. Metri-Pak 150's are good for 14A, Weather-Paks are good for 25 or 30 I believe.
Old 10-25-2010, 08:22 PM   #8
hades
can you get them local? Napa, lowes, etc?
Old 10-25-2010, 08:44 PM   #9
Seen then @ Napa a few times for sure..... How quickly do you need them?
Old 10-25-2010, 09:10 PM   #10
hades
i would say this weekend--but its Halloween -- which is a drinking holiday - which means I will probably sleep/hate life sunday.
Old 10-25-2010, 09:38 PM   #11
Ah, yeah, sadly I have to be at work friday-wendnesday at 7:00 or earlier.... so yeah, no fun for me this weekend...
Give a call to Napa and see if they have them, if not, hit me up and I'll drop a set in the mail to ya
Old 10-26-2010, 09:10 AM   #12
hades
Kinda scared to find out what else you would send. Would say bdc's head. But you havnt travelled through yet.
Old 11-04-2010, 04:44 PM   #13
hades
do you need the 144.00 tool to install these?
Old 11-04-2010, 05:13 PM   #14
No, the weather/metri packs can be installed with a $15 radio shack crimper, but it takes three different crimps to get them tight. The proper tool does a better job in one crimp. The deutch connectors on the other hand, or any mil-spec plug... I spent $320 on those crimps but OH MY GOD ARE THEY SOOOO SEXY....
Old 11-04-2010, 05:46 PM   #15
hades
thanks. we use deutch at work. I thought of getting help from a EE there, but they are not my favorite people.
