Rotary Tech - General Rotary Engine related tech section.. Tech section for general Rotary Engine... This includes, building 12As, 13Bs, 20Bs, Renesis, etc... |
Rep Power: 15 ![]() |
crank angle
series 5 13b turbo
what after market computers allow the crank angle sensor to be used? can i simply use the old mazda 13b turbo computer in my rx4 coupe? i want to keep the crank angle sensor thanks ! im off to beat some horses ! ![]() ![]() ![]() |
Rep Power: 17 ![]() |
Check out the aftermarket ECU or tuning forums here. I can tell you that the Haltech, Microtech, MoTec (if you are crazy rich) and Megasquirt will all use the factory CAS.
It is a 24 + 2 (home) sensor.
Rep Power: 10 ![]() |
Depending on how crazy you want to go with the engine, you could use the stock ECU to control the entire engine. If you're doing a transplant though I would give some serious thought to building a new harness with some bulkjead connectors. This way if you have plans to upgrade the ecu later in life all you need to do is build a strait harness from the ECU to the firewall.
What TTT means is Bulkhead connectors, or cannon plugs.
Bookmarks |
Thread Tools | |
Display Modes | |
