Old 03-30-2010, 12:19 PM   #1
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
J-Spec TII Vacuum Reroute
Will this set up work for me? I am putting a J-spec TII S5 into my S5 NA car. I have removed the ACV, Split Air, Air Pump (installed dual pulleys on the alt), and have installed block off plates, I am planning on keeping the BAC as I'm keeping A/C. I am unsure how the oil catch should be hooked up, could someone confirm setup? Also can the stock pressure sensor be blocked off or does it need to be routed to the manifold?
LunchboxCritter is offline   Reply With Quote
Old 03-30-2010, 01:23 PM   #2
If you are running the stock ECU then you need the pressure sensor hooked up. preferably the closest location to stock on the manifold. and don't forget there is a small pellet in that line...
Old 03-30-2010, 01:44 PM   #3
LunchboxCritter
Simply Rotarded
Okay thanks for the clarification (I am running OEM ECU). Here is a new diagram reflecting that. Is there anything else I'm missing or that I should know about this mod?
Old 03-30-2010, 09:44 PM   #4
LunchboxCritter
Simply Rotarded
Here is what I have so far. I ordered a Jaz oil catch and it should be here tomorrow. Please if you see something wrong let me know.
This is scary looking to me. I could be retarded but shouldn't the wastegate be hooked to a controller?
Some of what all that I removed. I also removed the two hard lines from the oil line that crosses the top front of the short block to the turbo. P.S. the starter is not part of the mod; it is a spare.
Old 03-30-2010, 11:42 PM   #5
LunchboxCritter
Simply Rotarded
Disclaimer: I am in no way a mechanic, and I did not sleep at a Holiday Inn. I do not even know if I am doing this mod right. Please don't run out and copy what I am doing. I could not find any good pictures of this job; however I did find a pretty good write up about the process. I am sorry, if I am doing something wrong, and I would appreciate suggestions.
DO NOT TRY THIS AT HOME!!!
Old 03-31-2010, 04:40 PM   #6
LunchboxCritter
Simply Rotarded
Just a few more pics.
Front of the TIM
Back of the TIM (firewall side)
Old 04-01-2010, 10:30 AM   #7
Gregory Casimir
so the oil catch can is hooked up in the right direction?
Gregory Casimir is offline   Reply With Quote
Old 04-01-2010, 10:48 AM   #8
LunchboxCritter
Simply Rotarded
I'm unsure of exactly how it should be hooked up, the diagram I colored was in hopes of some clarification. If someone knows for sure, please chime in here.
Old 04-05-2010, 10:40 AM   #9
LunchboxCritter
Simply Rotarded
Currently I have my setup like this, it fired right up and seems to run just fine. I am still short an exhaust and having only a downpipe installed I have yet to run it down the road.
I will adding a boost controller and boost gauge in the next few days and then my setup will be like this. I will inform everyone how well it works as soon as I know for sure.
Old 04-05-2010, 11:27 AM   #10
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
you capped off your waste gate, you need your waste gate solenoid to pull open off vacuum
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 04-05-2010, 11:33 AM   #11
LunchboxCritter
Simply Rotarded
You are absolutely correct.
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
Old 04-05-2010, 11:34 AM   #12
LunchboxCritter
Simply Rotarded
Thanks for pointing that out. I changed that before I started the car, I ran the turbo out and wastegate to a T fitting and then piped it to one of the vac on the front side of the top intake manifold. I have a manual boost controller that I'm going to put between the out on the turbo and the wastegate, and then I'll eliminate the hose running to the TIM. I'll get some updated pictures on here soon.
LunchboxCritter
- 88 FC Vert
- 04 Rx8
Old 04-05-2010, 12:58 PM   #13
why would you run a hose to the intake manifold? How bout just leave it like stock until the boost controller?
Old 04-05-2010, 02:03 PM   #14
Looky:
Connect those together.
There is supposed to be a metal 'ring' around the compressor coldside that has an output nipple. That nipple goes to the wastegate solenoid. If you are dumping the rats nest/emissions than you DON'T need it. Just connect the two together (compressor-to-wastegate).
Mine had the metal ring still, but I just capped it.
Old 04-13-2010, 05:15 PM   #15
LunchboxCritter
Simply Rotarded
Got a problem. Car won't boost, when it reaches half throttle and zero vacuum it stalls. Any ideas or suggestions?
Here is my current setup - Running an N374 ecu chipped with a speedlabs chip, n370 pressure sensor, correct maf sensor.
LunchboxCritter
- 88 FC Vert
- 04 Rx8
