Old 03-04-2008, 08:13 PM   #1
$100T2
Big Daddy
$100T2's Avatar
So I remember...
Somebody on some forum was talking about adapting second gen lower control arms to the FB.
Anybody know if that was ever successful??? Can it be done? Is it something we can work out here amongst ourselves?
Old 03-04-2008, 08:16 PM   #2
I would contact Billy at ReSpeed. It seems like he has alot of resto-mod experience with FB's, and I thought it was him.
I believe he has a sub-forum as well.
Old 03-05-2008, 08:44 PM   #3
rx7carl
rx7carl's Avatar
rx7carl is on a distinguished road
Omid and I believe someone else adapted the entire front suspension from an FC into a 1st gen. Actually didnt look all that difficult.
www.pbandjracing.com
rx7carl is offline   Reply With Quote
Old 03-06-2008, 07:13 PM   #4
aussiesmg
aussiesmg's Avatar
aussiesmg is on a distinguished road
I think it all comes down to the steering linkage and limited suspension travel
84 GSL with 5.0 SBF and T5
85 GS with 350 SBC and 350 trans, GRM Challenger
aussiesmg is offline   Reply With Quote
Old 03-08-2008, 08:59 PM   #5
$100T2
Big Daddy
$100T2's Avatar
Can the subframe from the FB be removed, and have the subframe from the FC modified and put in along with the FC steering?
I like how much more solid the FC control arms are over the FB.
Old 03-24-2008, 07:32 PM   #6
rx7carl
rx7carl's Avatar
I think so. But how will you mount the engine?
Old 03-24-2008, 08:56 PM   #7
I believe I've heard of the FC subframe being put under the FB - dont know the details though, but if somebody has a few parts cars and wants to check it out, lol...
Old 03-24-2008, 09:17 PM   #8
If you use the whole FC subframe, you could then easily swap in an FC engine. Instant EFI!!!
Old 03-24-2008, 09:59 PM   #9
staticpat
Rally Fanboy
staticpat's Avatar
staticpat is on a distinguished road
I've read on a rally board about that setup. It makes sense since there are a lot more suspension bits available for the FC. Not to mention better brakes, 5 lugs etc. I don't remember the specifics, but the subframe is supposedly a pretty close match. As mentioned, you'd be best off installing a 2nd gen engine with that setup. When I have more time I'll try and finding some more solid information. This is an idea I've been playing with in my mind.
staticpat is offline   Reply With Quote
Old 03-24-2008, 10:15 PM   #10
$100T2
Big Daddy
$100T2's Avatar
V8... Custom mounts anyway.
Old 03-25-2008, 09:49 PM   #11
staticpat
Rally Fanboy
staticpat's Avatar
Apparently a few people have swapped the whole front suspension. Here's a very brief overview.
Swapping to the 2nd gen suspension will require:
- Mounting the 2nd gen cross member (some holes, some welding)
- Attaching engine to 2nd gen cross member
- Attaching steering wheel to 2nd gen cross member
- a new pair of wheels up front that won't match your rear, unless you go four-lug and have GSL-SE in the rear.
- Close loop on 2nd gen steering rack (or add power steering pump)
Old 03-26-2008, 07:50 AM   #12
jgrewe
jgrewe is on a distinguished road
I've got a complete FC front suspension laying outside my shop if you want me to measure stuff for you. The whole assembly would be the easiest way to do it. You could probably take it all the way into the interior and have a tilt column from the FC pretty easily.
New rat from the sinking ship.
jgrewe is offline   Reply With Quote
Old 04-01-2008, 10:49 PM   #13
$100T2
Big Daddy
$100T2's Avatar
Yeah, measure it if you don't mind (or sell it to me ) and let me know. I'm doing a whole new dash anyway, so I don't mind bringing the FC steering along for the ride.
Old 04-17-2008, 08:51 PM   #14
jgrewe
I was walking around and tripped over the subframe and remembered this thread.
The front holes one the FC subframe are 31" apart, the rear holes are 31 7/8" apart, the front to back spacing of the holes is 13". The ball joint line is right around 1 7/8" to 2" behind the front holes. Those should get you a pretty good idea when you combine them with the published track width etc.
Any other specifics let me know. IIRC the height at the holes was all equal, I'll double check though.
Old 04-26-2008, 07:38 PM   #15
whitey85mtu
whitey85mtu is on a distinguished road
there's a writeup on the evil forum in the archives on how to install the FC subframe in the FB
whitey85mtu is offline   Reply With Quote
