Waffles - hmmm good
Budget 12A SP build
I'm working on building up an aggressive street ported 12a to replace my
current stock port. The current engine is very strong and still has a lot of life left in it and I intend to use it in another project. What I have are 2 engines I've purchased over the past 2 years. The first is a 12a that was rebuilt with a full Atkins Kit C for 75 bucks. This engine died swallowing a bolt. You can actually see the bolt threads on the exhaust port as it exited. Very entertaining, I'll get pics for you later. Anyway, for the money and if it had been built with a full Atkins kit C then its well worth it. The second engine is a original 12a that was just plain worn out and had little compression in the rear rotor. We will call the first engine A and the second B. Engine A I purchased for $75.00 and engine B I got for $50.00. Since this is a budget build my goal is to do a SP 12A for just a few hundred. So far I've got $125.00 into it. I expect a soft seal kit to be about $120.00 and then I may need to get few hard seals here and there. For porting I have some folks I can borrow or make templates from. Might get this done for less than $300.00, actually I have to because otherwise my wife will notice So the the A engine looks like it really has all the new stuff from an Atkins kit C. The apex seals are all like new as are most of the side seals. I'm still disassembling it but I have to think I can save some coin reusing a bunch of this stuff. The rear rotor is toast as it got beat pretty badly as it moved that bolt thru its rotation. When I got the engine the rear rotor was full of coolant. I flushed it with oil and wd40 and spun it with a my impact when I first got it to flush it all out. Surprisingly the rear housing has no big gouges or scores in it. I have to clean it up and measure it to make sure its good still but it looks pretty good. The front housing and rotor are in great shape. Reusable for sure. Too bad the rear rotor is trash because I think this is an 83 rotating assembly. The B engine is beat. All the seals are I'm sure out of spec and all the springs are pretty beat as well. The good news is that its an 80 12a. I like this because I want to use the side plates. Also the rotating assembly is in good shape. The bearings are worn but just showing a lot of copper, no scratches or weird wear marks on the eshaft. So my plan is to use the rotating assembly from the B engine along with its side plates and use the housings from the A engine as they have no flaking. So heres some of my questions. I will be measuring all clearances and so forth to make sure any reused pieces are in spec. I would like to try to reuse as much of the hard seals from the A engine as possible because that engine really wasn't run enough to even break in the engine. It sucked down a bolt and blew its coolant seal shortly after being installed. 1. Can I reuse the apex seals given they meet spec? 2. Should I reuse springs? They all seem like new. 3. Most of the side seals came out intact. Use em? 4. The oil control rings on the rotors came out with no problem. Reuse? 5. The corner seals are mostly good. Reuse? 6. Can I pull the bearings from the A rotors and reuse them? They look brand new, no copper at all! 7. Where the bolt went thru the exhaust port theres a gouge. I'll have to get a picture up of that but I'm thinking the street port of the exhaust may take care of it. I will of course get a complete soft seal rebuild kit for the rebuild. I know this thread is useless without pics. I'll get some I promise. I have to clean things up this weekend and then take the pics.
1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00 Last edited by t_g_farrell; 12-18-2010 at 10:10 AM. |
#2 | ||||||||
Waffles - hmmm good
Wow! Quick reply. Thanks.
These are 2 peice seals so, all good except one of the small corner pieces is broken. So the oil control rings are not shiny at all and I assume that means they are fairly new and reusable? Is there an easy or trick way to push out the bearings from the rotor? I have a large tool for pressing out various sized ball joints for trucks maybe I can use that. Maybe some heat would help as well. On the porting, I also think bigger is not always better but most of the SP exhaust looked they would cover this area. Need pics for sure so you all can advise me on that. I think I'll do the porting but haven't decided yet.
Waffles - hmmm good
I think I may use the A engine eshaft since the bearings are already matched
to that eshaft. I just have to get them pressed out carefully so I can reuse them in the B engine rotors. The A engine rear rotor is toast and I'm having to work pretty hard to get the hard seals all out. Mostly due to the rust that formed when it sat with the coolant in it.
1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00 Last edited by t_g_farrell; 12-19-2010 at 09:38 AM. |
Waffles - hmmm good
How do most folks get the bearings out of the rotors?
Favorite DIY methods or tools? I know I can take them somewhere and have them pressed out but if I can, I want to do it myself. More fun for me
Atkins sells a kit for use in a standard press. That is what I use.
Please check everything for tolerances, you will thank yourself later. Bearings are like $30.00 new (for 2) I think I would go that route, the chance of damaging them removing them is not entirely remote. There should be a small ring around the metal part of the oil control ring that rides on the plate. I would expect this to be shiny (unless it rusted in the coolant). If a seal is questionable, do yourself a favor and replace it. Better 1 seal than the whole rotor assembly. How not to port exhaust (note many changes in taper angle and flow restrictions, early open and late close). Made 255 WHp at 10 psi. ![]() Much prettier exhaust port (consistent, near ideal taper angle, no avoidable flow restrictions, stock open and close timing). Made 216 WHp at 0 psi.
1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) Last edited by NoDOHC; 12-20-2010 at 12:06 AM. |
#7 | |
Waffles - hmmm good
I'll be getting a full soft seal kit so I expect that will include the o-rings for the oil control seals. The A engine oil control seals look brand new, no shiny area at all. The B ones definitely look older and worn and are shiny about half way across, probably out of spec as well. Turns out I may be able to use the lighter weight rotors from engine A which already have brand new bearings in them. They look almost new. In fact everything from engine A is looking better than the B engine. The B engine side plates have noticable grooves in them from the corner seals. I may use the A engine front rotor housing instead of the B engine rear rotor housing which has the chunk chipped out of the exhaust port top opening. I'm thinking of trying out the Goopy housing resurface service. Its certainly priced right at $125.00 for a pair.
Waffles - hmmm good
Another question. My side housings show a darker coloring at the bottom
from after the spark plug hole over to where the exhaust would exit the rotor housings? Is this normal? I'm assuming this heat from lean combution but is it overheating damage? It certainly doesn't look like the typical iron overheat damage they show on the mazdatrix site: ![]() Otherwise they have almost no step wear, definitely nothing I can feel with my fingernail. I still have to spec them out to make sure they are flat enough. I know I need pics. I can probably get them up tonight.
#9 | |
If there is no shiny place on your oil control rings, they are likely new. It sounds like engine A really was a recent rebuild when it ate the bolt. Eating bolts is not that uncommon, I have a 90 4-port that ate a bolt (all seals were still ok, rotor and housing = junk).
#10 |
Waffles - hmmm good
Heres the A engine when I got it:
This is what all the oil control rings looked like. The rotor bearings (like new, mostly silver with a touch of copper at the seams) The damage the bolt did to the rear housing as it left the exhaust. I'm thinking porting will take care of it. If not I'll use one of the other housings from engine B. The right rotor shows a dent in the top edge of the combustion indent. None of the apex seals got damaged and none of the apex seal slots looks damaged. I think I can use the rotor? Opinions? Remember its a budget build.
#11 |
Waffles - hmmm good
I think I should explain the goals of this build. I call it a budget build because I
don't want to sink a lot of money into my 1st rebuild. This is a learning exercise for me and if it works well when I'm done great. If it blows up in a year, no biggie. Normally, if I was doing a full rebuild like this it would be with near perfect parts and all new hard and soft seals and springs. My next rebuild (see I know there will be another) will be of much higher quality. The other thing going on with this is that the engine its replacing in my SA, I will be keeping for another project. The current ignition, intake and exhaust can all be reused with this rebuild. Just some small jetting changes for the Dellorto. If the engines blows, I can just swap the stock port back in. I like doing it like this because it will keep a lot of unknowns out of the equation while I try to get my rebuild started and running the first time. Baby steps. Gotta walk before you run.
1980 GS stockport, Fat Nikki, RB Dual Facetfuel pumps, Holley regulator, RB Street port exhaust, 2GDFIS, MR2 MK I electric fans, 2G strut bar, relayed fans, lights and fuel pump, LEDs Project Fat Nikki Budget 12A rebuild Video setup < $30.00 Last edited by t_g_farrell; 12-21-2010 at 08:03 AM. |
#12 |
Those pictures reminded me, you have to keep the rotors separate on a 12A (they are different). I had forgotten that.
Let me put the porting to you this way, you can always take more out later. You can't easily add it back. Small porting is your friend. Intake port cross section should not exceed cross section of intake runner feeding it. Later close is only better if it greatly improves flow, don't dig a corner upwards just to match the majority of porting templates on the market today. I prefer the port to follow the shape of the rotor (quicker close = optimum dynamic charging, maximum port area without expense of compression displacement). Exhaust port should increase in cross-sectional area.
#13 |
Waffles - hmmm good
Excellent advice on the porting. I'll definitely keep it in mind when planning the
ports. Since I'm using the later 12a irons I do get a little larger intake runner size. I still have to decide which housings to use. First I have to get everything all cleaned up and measured to see what parts are even good
#14 |
Waffles - hmmm good
Not much new to report yet. I've been cleaning rotors, housings and irons.
I think I can reuse the dented rotor. It seems fine other than the dent near the combustion indent. I was able to get all the side seals out of it and the rest of the rotor appears fine. I think most of the A engine can be reused except for the rear iron. I think the rear iron from the B engine is actually in better shape. There is some mild stepping at the spark plug side but I'm thinking it will be in spec. I have yet to get some feeler guages for thousandths of an inch. The A engine irons are all Ys whereas the B engine irons are Rs. Is it ok to use the R iron with the other Y irons? Now that I cleaned em up I don't see huge differences between them. The stationary bearings don't look new like the rotor bearings. Some copper showing on the lower part of the bearing and at the seams. They don't look that much different from the ones in the B engine, which had a lot of hard miles on it. Thinking I may need to change those out. I pulled the e-shaft oil jets and they had disintegrated o-rings in them. I think I can safely say those were never replaced. I'm thinking about doing the oil pressure mod to the regulator where you mash down the tip to get it to about 90 psi and shim the front one. This will be a SP with spirited driving and some track days. Is it worth it? I don't think I need to do anything with the e-shaft jets other than new o-rings. I can't see having extra pressure being a problem as long as my lines and cooler can handle it.
#15 |
If the dent has not deformed any seal grooves, the only thing that you need to worry about is the balance. That will probably be fine, as street ported engines don't typically make much power over 8,000 rpm anyway.
As to the oil mod - I have never done it, and to my understanding it is intended for high rpm operation. Your street port will not be likely to operate much outside the standard rev range, so I don't know that it is necessary. As I said, I have not done it and have never had bearing trouble from overrevving (redline at 9,000). As I said before, check tolerances on everything, the FSM is an excellent resource.
