Old 10-21-2010, 09:47 PM   #1
Mateepay
Mateepay is on a distinguished road
tach not working???
i need some help ive replaced the tachometer in my 83 rx and havent had any luck getting it to work..... it spikes a inch on start up and wen i do a cold rev engine shutoff.... im loosing patience with this does anyone know of a possible fusible link or anything im missing that will get this working??
Mateepay is offline   Reply With Quote
Old 10-21-2010, 09:52 PM   #2
FC Zach
FC Zach's Avatar
Is your trailing coil good? Was it working fine prior to the swapping?
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 10-21-2010, 09:54 PM   #3
Mateepay
the car runs and drives fine anyway to tell wether the trailing is good?
Old 10-21-2010, 10:46 PM   #4
FC Zach
FC Zach's Avatar
If you have an OHM meter you can measure the resistance between the primary (+ & -) which should be around 0.1 on your coil but I'm not exactly sure on the specifics, if you have a Haynes it is in there.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 10-21-2010, 10:50 PM   #5
FC Zach
FC Zach's Avatar
If it hasn't worked since you purchased the car then there is a chance that the Yellow/Green tracer wire (i think green tracer) may not be connected, but then again you did state that the needle does jump. ? ? ? weird
Edit: The yellow/green tracer wire is the signal wire for the tach.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
Old 10-21-2010, 09:56 PM   #6
Mateepay
and the cars tach hasnt ever worked since i bought the car in may
Old 10-21-2010, 11:10 PM   #7
Mateepay
I believe every wire that needs to be connected is. distributor and coil connection. My car back fires alot and I mean alot could that be an attribute of no trailing plug ignition or poor ignition becouse of a bad coil?
Old 10-22-2010, 02:00 AM   #8
Kentetsu
Kentetsu's Avatar
Pull a trailing spark plug out and check for spark (keep it away from the fumes that will exit the plug hole when you crank it over). Could be a bad coil, or ignitor.
Old 10-22-2010, 07:14 AM   #9
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Move the coil signal wire from the trailing to the leading coil and see if that
helps your tach.
With all the backfiring you either have a spark issue or a fuel issue or both.
If you can rule out the spark then you can work on the fuel. Kind of hard to
deal with a fuel issue tho ift he spark is unknown quantity.
Old 10-22-2010, 09:19 AM   #10
Mateepay
Checked the trailing plugs and didn't get anything so maby my problem lies with the coils going to get some today if that doesn't solve the problem with the tach I guess that would leave the wire
Old 10-22-2010, 10:06 AM   #11
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Check your ignitors first.
Old 10-23-2010, 02:02 PM   #12
Mateepay
pUt the new coil in... Nothing pulled some used ignitirs guess that's my next try
Old 10-23-2010, 09:56 PM   #13
Mateepay
trailing ignitor was the issue!!! thanks for the help now....... to takle the delorto carb and sidedraft set up
