Go Back   Rotary Car Club > REGIONAL FORUM > West RCC forum > California
Old 12-26-2008, 02:02 AM   #1
hyperlitenerd
Captin Safety
hyperlitenerd's Avatar
hyperlitenerd is on a distinguished road
Thinking about some mods...
Well Christmas has given me some money with instructions to do something fun with it. So I am thinking about a Greddy Profec B Spec 2, Fighters Garage intake, and Fighters Garage toe links.
I am trying to talk my self into doing these mods. Does anyone have any experience with them? Will the intake give me trouble with smog?
hyperlitenerd is offline   Reply With Quote
Old 12-26-2008, 03:01 AM   #2
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
Greddy Profec is a pretty nice BC; kinda confusing to set - but good results.
I have it and recommend it.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 12-26-2008, 03:05 AM   #3
hyperlitenerd
Captin Safety
Yeah I've been kicking the idea around for a while. Since I seem to over boost from time to time it would be nice to not have to watch the boost gauge when I got WOT
Old 12-26-2008, 10:59 AM   #4
Hmmm, I believe if you are overboosting and you are not changing the wastegate spring....Then the Boost Controller won't help your overboost. Alll the BC does it control when the wastagate is exposed to the signal boost reference so if it has a 10psi wastegate and a 15psi boost goal, the BC will not allow the boost signal reference to reach the wastegate until you reach 15psi. But the lowest boost pressure it can achieve is to allow the wastegate to see the signal the whole time....the same as having no boost controller at all
Old 12-26-2008, 01:32 PM   #5
Kane
All about the O2
Kane's Avatar
^ This is correct.
Unless you are switching from a MBC to an EBC; then this would be a good modification to buy.
Old 12-26-2008, 02:26 PM   #6
hyperlitenerd
Captin Safety
Let me re-word what is happening to make sure we are talking about the same thing. It usually happens in 4th gear at highway speeds, it will go up to like 14psi, and if I keep my foot in it, it will drop down to about 11psi.
Old 12-26-2008, 02:45 PM   #7
Kane
All about the O2
Kane's Avatar
And you want to keep it at 14 PSI right? BTW - that is not called spiking/overboost (assuming you want 14 PSI) - that is boost fall off.
If that is the case; then a BC is for you.
Old 12-26-2008, 03:18 PM   #8
hyperlitenerd
Captin Safety
I guess I should have said that my car is 94 rx7 with a downpipe. I am trying to stay at the stock boost level of 10psi.
Old 12-26-2008, 04:18 PM   #9
Kane
All about the O2
Kane's Avatar
Ahhhh - now the problems start to come out - the second turbo is spooling too fast for the stock PCM settings.
Assuming all of your wastegate lines are stock and working correctly; an Apexi PFC or the like is going to work way better than a BC. A BC cannot take anything away - only add.
Sorry man.
Old 12-26-2008, 06:43 PM   #10
Kane
All about the O2
Kane's Avatar
To add - I found this wicked vacuum hose diagram when I did the single turbo swap (on RX7 club I believe) - we made it poster sized and laminated it - I don't have it any more - but that kind of thing would really help you get your set-up correct.
Old 12-26-2008, 06:53 PM   #11
Kane
All about the O2
Kane's Avatar
The blocked image?????
Old 12-26-2008, 08:28 PM   #12
hyperlitenerd
Captin Safety
Well I have talked my self out of the toe links. I am still thinking about the intake and the boost controller. I am tempted by the 99 spec wing, but I don't know if I could swing to buy it, paint it and have it installed.
Doesn't it look sooo nice with on montego blue.
