|  05-01-2008, 06:12 PM | #1 |
| Victory Is Mine Join Date: Feb 2008 Location: Suwanee GA
				Rep Power: 18  |
				Car wont start: weird clicking under intake manifold
			I was trying to start my car again today and it wont start, it fires everynow and then and tries to start but dies.  When I hold the key in the on position without trying to start the car there is a clicking under the upper intake manifold that I have never heard before could this be what is the issue?   Im open to any ideas, I just drove the car like 30 miles last month with what seemed like no problems and havent changed anything other than the PFC maps. Thanx Jeremy
				__________________  www.dealsgaprotaryrally.com 1994 Rx7 White 2001 RZ GT35R'd 1972 Rx2 Orange Coupe 5spd 2006 STi 1986 Buick GN |
|  05-01-2008, 06:43 PM | #2 |
| Rotary Fanatic Join Date: Mar 2008
				Rep Power: 18  |
			Just a wild guess but it may be your injectors...it could be clogged or gone bad...
|  05-01-2008, 06:45 PM | #3 |
| RCC Contributor Join Date: Jan 2008
				Rep Power: 18  |
			The injector should not be receiving any signal until the trigger wheel behind the main pulley starts to turn, Im not saying it is impossible for that to be it but I wouldnt think so.
				__________________ David Jerome Broker for Speed For Sale LLC (David@SpeedForSale.com) (Pre-owned RX7/sports car sales & new parts sales/installs/tuning)  PM me about low priced, high quality port work   |
|  05-01-2008, 06:44 PM | #4 |
				Rep Power: 18  |
			Sounds like your ISC (Idle Speed Control)  I really wouldnt think that it would prevent it from starting, however it will definately effect your idle once started.  Just disconnect it and turn the Idle Speed Screw counter clockwise a couple times and then readjust it once you start the car.  The ISCs fail commonly and make weird noises.
|  05-01-2008, 10:40 PM | #5 |
				Rep Power: 18  |
			which one is the ICS again?  I think I may have blocked that one off when I took all the emissions off? So it may not even be there. l8r
|  05-01-2008, 11:58 PM | #6 |
				Rep Power: 18  |
			Back of the UIM with the white connector on the wiring harness going to it.
|  05-02-2008, 12:33 AM | #7 |
| Rotary Fanatic Join Date: Mar 2008 Location: Brenham, TX
				Rep Power: 18  |
			i agree sounds like the ICS, unless an injector wire is somehow grounding out. Pull the plugs and see if the car is flooded. The ICS shouldnt keep the car from starting as David stated.
				__________________ 500+ HP thanks to:  Fast reacting IAT sensor thread! Mechanical Pre-turbo Water Injection Thread Dual Stock fuel pumps Thread T2 differential swap! |
|  05-02-2008, 10:05 AM | #8 |
| Rotary Fan in Training Join Date: Feb 2008 Location: Las Vegas
				Rep Power: 0  |
			Check to see if you have spark, maybe one of your coils has died
|  05-02-2008, 10:36 AM | #9 |
				Rep Power: 18  |
			Hmm, im gonna check these things out but I have recently just checked most of this stuff and it was all fine. I think the car is flooded from running too slow at idle untuned when I last had it running.
|  05-02-2008, 10:50 AM | #10 |
				Rep Power: 18  |
			If you start to car and it dies immediately after about 2 or 3 shots you can pretty much gaurantee that you have fouled the plugs.
|  05-02-2008, 06:04 PM | #11 |
				Rep Power: 18  |
			Well, I just tried to start it again today and looks like now im not getting any fuel presure from the pump. Either it isnt coming on or its not being told to come on.  Zero nada zip for presure at the engine.
|  05-05-2008, 09:30 AM | #12 |
| Rotary Fanatic Join Date: Feb 2008 Location: B'ham, AL
				Rep Power: 18  |
			Is the pump coming on??
				__________________ 1993 Rx-7 SM2 #11 At the local AutoX: http://www.youtube.com/watch?v=9VOSQkkSLQs Speed for Sale shootout 2007: http://www.youtube.com/watch?v=JiqlyAkGmpg A few laps at Barbers: http://www.youtube.com/watch?v=6_h5q...x=0&playnext=1 |
|  05-07-2008, 02:35 PM | #13 |
| Founder/Administrator/Internet Pitbull :) Join Date: Jan 2008
				Rep Power: 10   |
			Thats crazy!!! What pump are you running?
				__________________ DGRR 2013 - Year of 13B www.DealsGapRotaryRally.com http://www.facebook.com/Herblenny |
|  05-19-2008, 11:18 AM | #14 |
				Rep Power: 18  |
			Well shit, I just got finished changing out the pump yesterday to a Supra Denso pump that I wanted to do anyhow.  Well I still am not getting any pressure with the key in the on position.  I cant beleive that its leaking past the injectors again?  I have not even driven it  more than 30 miles since I got it back from the shop and it was holding pressure fine when I got it back from them.
|  05-21-2008, 09:14 AM | #15 |
				Rep Power: 10   |
			Did you check the fuel pump relay?
