Fabrication Show off the parts that you've built from scratch or highly modified |
custom stainless intake
My custom stainless lobster back N/A intake
Don Mega
very nice welding, great work.
Rep Power: 15 ![]() |
I would love one of these, but fiberglass wrapped to help keep intake temps down.
I can sell you this one if your interested? All i have to do is weld the flange on yet. Its cut already just need to weld it on
Professional Stick Poker
I hate to point this out, as you've done so much nice work on it, but how do you intend to compensate for engine movement? Even with solid motor mounts there is a little bit of movement.
#6 | |
I'm sorry, but having that long, honkin' thing hanging off the TB is still mass dealing with vibration - i.e. physics. Even if you "spring mount" the AFM, that's even more mass... Also, stainless steel has this nasty habit of soaking heat. That duct is hanging over the exhaust exit out of the engine. There's a reason why Mazda designed it as a rubber flex unit. If they didn't need have to worry about flex and vibration, a plastic unit would've been lighter and cheaper to install. I agree that your welding skills are top-notch, but I question the practicality of this application? -Ted |
#7 | |
Well once it bolts up to the throttle body itll sit there like the stock intake and i have a spring mount that will support it close to the maf. So should be no problem
#9 |
If i was using the car more than just weekend cruising id be mor concerned about it. If it gets to hot ill ceramic coat it like i did all my intake manifolds
#10 |
Meh we will see. Worth a try
#11 |
Give it a shot. It seems I've spent at least half my time redoing stuff that didn't quite work out the way I had envisioned on my own project. It didn't work, but it was always instructive.
#12 |
Heres a picture of it sittin by itself. Tacked the flange on today
#13 |
KTEC
Seriously. Worrying about intake vibration? It's just an intake tube... I seen many FC's with zip tied flow meters and cobbled together eBay piping intakes.
Nice work man. I hate cutting stainless so i know some dedication went into this.
#14 | |||
Vibration (to the AFM) is not what I would primarily worry about. I would worry that it would crack... Quote:
The car might run like shit, but most of these types of owners are just happy to drive down the road and back... Sadly, having the car run at it's best is not something they can afford to do. So, I don't see what your point is...? Quote:
With this kinda skills, I would suggest looking at other, more better applications of such skills. Exhaust headers would be an easy example. As you have already pointed out, FC owners are cheap asses. The OP mentioned possibly offering this type of product for sale? Unless priced ridiculously low (like under $20), I doubt it would sell to maybe a select few who wants to own something different without flinching at the price tag. We're just offering constructive criticism... -Ted |
#15 |
^ haha thanks man. I completely agree. I know mazda took that into account when engineering the maf
Bookmarks |
Thread Tools | |
Display Modes | |
