KTEC
added a 12v plug
So i added a 12v outlet in my car for various reasons. I checked it with a multimeter at the plug and its getting correct voltage, but its popping the inline fuse i put in.
I just got a simple connector and plugged it into the power side of the auto seatbelt fuse slot since I no longer have them in the car. I chose that one because it gives constant 12v power. I ran a wire to a inline fuse before reaching the 12v outlet. The 12v outlet only has two wires on it, power and ground. I grounded the one to a near by bolt. And ran the power wire from the outlet to my power source. It pops the inline fuse pretty much instantly if i have something plugged into the outlet. Any ideas?
Rep Power: 20 ![]() |
What size fuse?
KTEC
well, i tryed a 15amp and a 20amp. The seat belt fuse slot is a 30amp, so that might be the reaosn. But then i tried a few other slots that only have 10-15 amps. They still bust the 20amp fuse. I then tryed the 12v power from my ignition wire, and still popped the fuse... I checked my ground coming off the 12v outlet for continuity, just to make sure its a good ground. Yupp... good ground. So whats the problem???
I put in an Add-A-Fuse with a 15amp fuse for my extra outlet and haven't had any problems running a phone charger. Wish I could help more.
KTEC
add-a-fuse? is that the thing that looks like a fuse but has a power wire coming off of it? seen that at autozone, but i was unsure it it would make a difference?
Yeah, it's basically a fuse holder with a wire coming off of it.
Rep Power: 10 ![]() |
Have you tried different plugs? That could internally shorted. Other than that the outlet's fucked
KTEC
what do you mean by "different plugs"?
#9 |
try a cell phone charger
then try a small inverter then try am ipod adapter then try a 12V ballscratcher then try the sweedish grip suck machine then try.... well you get the idea
#10 | |
Big Ugly
Rep Power: 17 ![]() |
Boosted Big Body On 335's PS3 ID: Rotordad 1986 Mazda RX7 GXL - Street ported 13BT, Haltech, 62mm, ect. 2006 MazdaSpeed 6 - Eagle, Wiseco, Cobb, ect. |
#11 |
KTEC
Actually i tryed a few different plugs... And i tested the inverter in 2 other cars, it worked fine.
#12 |
Do you have the ground and power wire connected to the correct spots on the plug? IIRC the power is the center one and the ground is the whole outside portion.
#13 |
You would be correct
