Old 02-25-2008, 02:15 AM   #1
turboed13b
turboed13b is on a distinguished road
engine rebuild question
quick question would the overhaul kit "A" from atkins rotary be the only thing i need for a engine that has been rebuilt but the coolant seals failed?
turboed13b is offline   Reply With Quote
Old 02-25-2008, 12:41 PM   #2
David Jerome
David Jerome's Avatar
Post this in RotaryResurrections vendor section as he will have the answer you need.
David Jerome
Old 02-25-2008, 10:07 PM   #3
turboed13b
well the engine only has a couple thousand miles on it so the apex seals should be good right?
Old 02-27-2008, 01:27 AM   #4
spankle my wankle
spankle my wankle is on a distinguished road
hahaha ^+1
spankle my wankle is offline   Reply With Quote
Old 02-27-2008, 12:50 PM   #5
SpooledupRacing
Guest
Posts: n/a
I agree with Kevin... I would pull the engine apart and inspect it FIRST maybe post pictures if u have questions.. but I would replace all the seals and o-rings at the bare minimum...
My question is who rebuilt the last engine, why did the coolant seals go out?
Old 02-28-2008, 01:40 AM   #6
AwakenNoMore
AwakenNoMore's Avatar
AwakenNoMore is on a distinguished road
Might as well cover all your bases and refreash anything you can, and heck if your going to open it up why not clean up the ports a bit too? Or is it already ported?
1993 VR Touring, motor built by Arizona Rotary Rockets.
AwakenNoMore is offline   Reply With Quote
Old 02-28-2008, 10:57 AM   #7
Kontakt
GTA Bryson City
Kontakt's Avatar
Kontakt is on a distinguished road
Originally Posted by RotaryResurrection View Post
It would be kinda dumb to just replace the coolant seals and slap it all back together. You at least want to replace the parts that I replace in my basic rebuild. Coolant seals/dowelpin orings/tension bolt seals, front/rear main seals, apex seals (springs can be reused), cornerseal springs, viton oil control orings, thermal pellet.
I dont use a particular kit so I can't say wha tis contained in each. Use the list above as a minimum purchase list.
I made sure to replace my side seal springs as well. I think that's the only thing I didn't see on your list that I would do.
Kontakt is offline   Reply With Quote
Old 02-28-2008, 03:32 PM   #8
SoGlow7
SoGlow7's Avatar
SoGlow7 is on a distinguished road
So basically you won't know everything you will need until you open it up, but yeah since your taking out the engine, might as well look at all the other parts in the bay. And give it a good scrub down too
SoGlow7 is offline   Reply With Quote
Old 03-04-2008, 09:16 PM   #9
Kontakt
GTA Bryson City
Kontakt's Avatar
SS springs are usually fine to reuse, unless it is an NA with 4011 thousand miles on it that has a ton of carbon in the grooves, and bends them up on removal. Sure, in a perfect world we would all have engines full of new parts, but we have to draw the line somewhere in order for our budgets to survive intact.
As I've said before, I believe the art to building rotaries is not so much in knowing how to assemble parts...anyone can do that. It is knowing what you can and can't get by with reusing successfully.
Yeah about half of mine wouldn't come out without destruction, so I needed new. Even so they're pretty darned cheap. In my build if it was under $20 I got it whether I needed it or not. I did pretty much all springs, all rubber, apex seals, and such.
Originally Posted by mazpower View Post
I have no idea how you're getting that kind of mileage. It damn near defies physics.
Originally Posted by yzf-r1 View Post
Axiomatic. Countless case studies.
