Old 11-15-2013, 11:18 AM   #1
Whizbang's Rally Car v3.0! The SABCD
Now with more SA! and more roll cage!
1979! Cage was logbooked through Rally America in 2011. Never raced.
The kirky seat is just a roll around seat until i make the proper mounts. Game plan is make the turret mounts for rear suspension, upper link boxes for the four link, seat mounts, plug the sunroof, then paint the inner up.
Obviously, there is much to do. FC front suspension, toyota 8" rear axle w/ four link / panhard. Haven't settled on an engine yet.
Old 11-17-2013, 01:47 AM   #2
GySgtFrank
Professional Stick Poker
GySgtFrank's Avatar
That looks like a really stout cage. You planning on running in a faster class or staying where you were running? With all the legendary tracks out there, do plan to do any track racing?
Old 11-17-2013, 09:05 AM   #3
banzaitoyota
banzaitoyota is on a distinguished road
"like"
My deuce
banzaitoyota is offline   Reply With Quote
Old 11-17-2013, 11:50 AM   #4
same class (Group 2). Basically my old car was "grandfathered" since it was hella old. but any newer builds have to be up to date for the cage standards, which basically results in this jungle gym in the Rx-7.
I might take it to a track day or two for giggles. I can swap out the suspension for something more suited.
Old 11-17-2013, 10:23 PM   #5
by the way, Group 2 for the rotary means "non ported" engine. Group 5 is where you find anything NA and greater than 3.0L adjusted displacement, or forcefully induced (or both). Ported rotaries just get pushed into it.
my friends Integra is a group 2 car (which we are racing this weekend in Az. woot). Its a Honda ITR engine making like 193 whp or some crap. So that is the kind of competition car wise i have to deal with.
and thus i am considering the 13B-MSP since Rx-8 stuff is hella cheap and with stock whatnot, i can make ABOUT that same power level.
Old 11-18-2013, 03:07 AM   #6
GySgtFrank
GySgtFrank's Avatar
Why not Mazda's 2.5 or 3.0 V6 (if the 3.0 squeaks under the rules)? The 3.0 was rated at 232hp and the things are hella cheap. The V6 would allow you to keep the engine behind the front wheels for weight distribution and they're all aluminum so fairly light. The new series V6s are even lighter and stronger, but I would imagine more costly to get hold of.
Old 11-18-2013, 10:44 AM   #7
i would but they basically have no good transmission options, as well as, the rotary just being simple and small.
if i go V6 it would probably be a 350Z
Old 11-27-2013, 03:32 PM   #8
Brought the Toyota 8" axles and housing. EVERY 3rd member was gone. But this will let me get the axle housing done up for the four link and the axles machined.
Old 01-21-2014, 01:18 AM   #9
car is home! time to sort out the parts and get rolling
Old 01-26-2014, 09:53 PM   #10
stripped down and ready for all kinds of more work
Old 02-11-2014, 09:15 PM   #11
Order camber plates so i stop tearing out the rubber from OE mounts. Also orders the wider ZG flares for the car.
I toss and turned on using mariah mode 1 widebody components to make a pseudo Group B look but the costs just plain deter me from doing it. And then factor that rally breaks things.
I AM getting the Group C wing though damn it.
Old 02-12-2014, 02:37 AM   #12
GySgtFrank
GySgtFrank's Avatar
Smart move. Breaking stuff gets expensive. Racing is expensive.
Old 02-14-2014, 01:35 AM   #13
pics of the various things!
new OMP HTE seat.
Cut a big fucking hole in the floor pan for seat mounting reasons.
subframe is installed!
my 40mm inverted bilsteins, and T3 camber plates (hopefully they work out)
Old 03-20-2014, 01:11 PM   #14
Old 03-21-2014, 12:29 AM   #15
any idea how to go about making something like this? modding the factory LCA to something that isn't a rubbery binding mess.
