Old 05-23-2010, 01:00 PM   #1
89Rotary
GTUs 6 Port
89Rotary's Avatar
89Rotary is on a distinguished road
Rtek 2.0 Tuning
Hey guys, its been a long time since i posted. but i've got my new motor installed and running Large Street ported
so my question has anyone used a Rtek 2.0 to tune with?? i've got one and i wanna hold someones hand and bounce idea's before i start changing Timing and Fuel.
Thanks alot guys!
Jake B "Built NEVER Bought"
1989 Mazda FC3S GTUs
TII Swap In Progress
"Days Of Spoken Legend Has Come To An End, The Curtain Of The New Rotary Era Has Been Raised"
89Rotary is offline   Reply With Quote
Old 05-23-2010, 01:25 PM   #2
I have an RTek 2.1 (the new version that fixed some issues I had with 2.0) for an NA motor. It's not that bad, but I'm looking to upgrade here in the coming months.
Old 05-24-2010, 05:11 PM   #3
89Rotary
GTUs 6 Port
89Rotary's Avatar
Did you do any real tuning with it? or did you just install it?
Old 05-24-2010, 05:46 PM   #4
I've tuned it to use my turbo (remember, it's an NA)... I don't suggest it, but I've altered the fuel curve, haven't touched the timing, which is probably why I have an issue with spark break up around 3000RPM, but i'm going to full stand alone for some much needed features.
What are you attempting to do?
Old 05-25-2010, 10:59 PM   #5
89Rotary
GTUs 6 Port
89Rotary's Avatar
I've just finished breakin in my 6 Port Motor N/A and wanna SAFELY squeeze some power out. i just want to know basic's of where i should move timing, and when and how to play the Leading/Trailing Dance. Fuel i can Watch with a NB (WB Later) for now.
Old 05-26-2010, 10:02 AM   #6
Honestly I could tell you some numbers, but there's really no need for a few reasons:
You can not tune fuel with a NB. It can only tell you if you're off stoich (rich or lean), but can't tell you how much. IE usually making peak power at a 12:1 AFR (or 0.8 Lambda). Consequently the timing is more sensitive to what type of gas you're using. If you're using regular (as stated by the Owners manual) stock firing is fine--can verify by strapping it to a dyno and going from there. If you want to adjust timing, you'll need to put it on a dyno (don't go by feel), and slowly adjust it from there. Depending on your spark energy you should see some decent gains (don't forget to go to a higher octane rating when you adjust it).
Old 05-26-2010, 04:41 PM   #7
89Rotary
GTUs 6 Port
89Rotary's Avatar
I understand all that. but, Being as i have a Large Street Ported Motor, Factory timing isn't correct anymore right?
Old 05-26-2010, 06:16 PM   #8
Eh, it's not going to hurt anything. (I'm currently on a large street port)
http://www.rotaryengineillustrated.c...t-port-14.html
^Some reading to give you an idea.
Old 05-26-2010, 11:11 PM   #9
89Rotary
GTUs 6 Port
89Rotary's Avatar
Awesome thank you
Old 05-29-2010, 09:43 AM   #10
Just a little adjustment/caviot: Timing is not my issue; fuel is. The NA RTek can not tune for positive pressure (anything greater than 5 psi), as such fuel gets dumped into the engine down to 9-10:1 AFR at 3000RPM (when I'd actually begin to see positive pressure at partial throttle).
fuel tuning, rtek tuning
