Go Back   Rotary Car Club > REGIONAL FORUM > Southeast > North & South Carolina
North & South Carolina Mazda Rotary Car Club of North & South Carolina
Old 07-11-2008, 12:19 PM   #1
87turbo_turtle
Rotary Chic
87turbo_turtle's Avatar
87turbo_turtle is on a distinguished road
this is making me mad
ok this is making me mad
Alright first off i did search and found a lot of help full info and tried a lot of the stuff i found. i even broke out the haynes and tried that stuff. Ok with that out of the way ill start with the story.
Ok as some of you may know in oct 07 my na went BooM!! so i was time to start over and find another motor. well we bought a jdm 13bt. then we found a 87 gxl with a clean title and over all just clean but the motor was gone . so we decided to throw the turbo in the 87 and have a go at it. here is a quick list of stuff we did.
Fmic
Greddy type rs bov
full 3 inch exhaust
intake
255hp walboro fp
got some block offs
new silicone vacuum hoses
Then we droped it in the car. it ran but then it started smoking all in the same 10 mins (it warmed up). so it was time for a rebuild. so i ordered the normal.
gasket set
new lower intake gasket
oil control orings and springs
side seals and springs
2mm 2 peice apex seals from rhd japan and springs
solid corner seals and rx8 corner seal springs
thermo pellet
we put the motor back together (we = my best freind brian who has rebuilt a few his self) it has awsome comp. but hes out of town and now i have to do the timing
myself. it seems really easy you line up the yellow mark on the pulley with the pin on the front cover. then pull the cas and match up the mark on the shaft with the mark on the gear. hold the gear with ur palm or thumbs which ever you prefer and drop it in and start it up. sound easy but i have dont that and all it does it tuen and try to start then just turns some more and gets flooded.
ok heres what i have tried:
set the pulley on the yellow mark match up the cas= same
set the pulley on the yellow mark turn the cas gear back 2 ticks=same
set the pulley on the red mark match up the cas=same
set the pulley on the red mark turn the cas gear back 2 ticks=same
i know for sure that i have fire and fuel but this is really making me mad. if theres ne one in the south carolina or columbia area that can offer some help that would be great. although ne help would be great because i am jsut at the end of my rope with this car.
Turtle
Yes I am a girl and I will kick your butt.
Prove yourself.
87turbo_turtle is offline   Reply With Quote
