Old 02-15-2012, 11:40 AM   #1
t_g_farrell
Waffles - hmmm good
t_g_farrell's Avatar
Talking Project Fat Nikki
I've procured an 85 nikki and intake manifold from pullapart for some fun.
My goal is to hog out this nikki to the best of my abilities so that it can be used in
place of my current Dellorto setup. I have no compelling reason to do this, the
Dell works great. I just thought it would be fun to do. It will initially go on my
stock port 12A.
I'm cleaning and disassembling right now and will get pictures up as I go along
making the various mods. I know I could get a sterling (maybe) or from SR
Motorsports but I want to do it myself.
So I'll post my detailed plan for the modifications to be done. Please feel free
to post up anything I may be missing or can do better or have first hand
knowledge about that can help me out. In return I promise to deliver lots
of details and pictures as I go along.
Heres the plan. I've numbered each step uniquely and grouped then logically
by component to make discussions easier. If nothing else I hope this helps
anyone else contemplating hogging out their nikki.
AIR HORN mods
done A1. remove choke plates and rod and seal up holes
done A2. remove choke diaphram and brackets, plug holes
done A3. dead head fuel inlet for now. Just cap with bolt and gasket. Keep return and other gasket just in case.
kept A4. remove air vent solenoid, plug with bolt
But disconnected
done A4. remove alt. compensator, plug holes
MAIN BODY mods
done M1. remove dashpot and bracket, plug holes
done M2. remove secondary diaphram, plug holes
done M3. remove TPS
done M4. Drill out AP jet, top center and top 2 holes to .5mm
skipped M5. Drill out AP nozzle to 0.050 "
done M6. Double up gaskets on AP diaphram
done M7. Add extension to AP pump arm.
done M8. Pull primary and secondary booster venturis and cut extra arm off and smooth remainng arm
also polish up inside each venturi to clean up and smooth it out.
done M9. Mill down primary and secondary venturis a little bit
done M10. Drill out fuel and air jets. Or buy holley air bleeds for fuel and only drill air jets.
- only drilled the primary fuel about 1mm or so.
THROTTLE BODY mods.
done T1. Hook up mech secondaries
done T2. strip down linkages to bare minimum
done T3. cut half of secondary shaft away, use shorter small cap hex bolts to attach butterflys
skipped T4. use small cap hex bolts to attach primary butterflys.
INTAKE MANIFOLD mods
done I1. remove butterfly and rod, fill holes
done I2. cut channel between rear primary and seconday opening
I3. install ACV blockoff plate
I4. cut or plug pipe off of the back of the intake
done I5. plug or cutoff extension off rear of intake
Plugged with JBWeld
12a, carb, nikki
