Magic Spinning Triangles
Premix at the pump
The next time I take my FC to the pump, I plan on pouring in some 2-stroke premix. About how much premix should I add per tank? What type of premix do you guys use?
I was thinking of using Royal Purple 10W30 and premix once spring (racing season) comes around, but I'm sticking with 10W30 conventional for the winter. Stock S4 N/A 13B. The oil metering pump is in place and working.
'87 Mazda RX-7 GXL: Solo E Stock-bound '98 Subaru Impreza: The Daily Beater |
Rep Power: 21 ![]() |
I generally use about 1oz per gallon.
Rep Power: 17 ![]() |
every time you roll over a couple of gallons, add a couple of ounces. 1 gallon of gas/1 ounce of oil is the rule of thumb.
why do you need to premix if you still have the OMP? |
Evil Club Mod
If you have the OMP still working, 3-5 oz per TANK, is all you really need
#5 | |
Home-brew Rotary
'89 RX7 GTU, half-Bridge-port S4/S5 NA, E6K, Full RB exhaust, weekend warrior. '83 RX7, The "this might take awhile" project. '87 RX7 GXL, Rest In Pieces. '98 Subaru Impreza Outback-sport, rx7 rescue vehicle, down for repair. '94 Ford Ranger, daily. |
I only use the best for mine...
![]() 1oz/gal |
#9 |
Keep in mind guys - as it always in when premixing anything (cars, bikes, lawnmowers, etc) you add the oil to the tank FIRST and then add the gas... otherwise it won't mix evenly. You use the pressure from the gas pump to slosh the oil around and mix properly.
If you are using the stock OMP you really wont need more than 3 to 5oz like others have mentioned. Going more than 100:1 is a bit much.... |
#10 |
Rep Power: 20 ![]() |
I use the Wal-Mart cheap stuff. Let's be honest here, unless you're running some obscene hp (or something...), I really really doubt you could tell the difference after 100,000 miles between mine and the stuff that costs 5x as much.
#11 |
i use wal-mart stuff as well. 1oz/2gal. and im at 417whp.
#12 | |
Though, if you could collect all that carbon and make Apex Seals out of them... |
#13 | |
I use the Penzoil Marine Pre-mix
#14 |
If it has TCW3 on it, I try it. Haven't found my favorite yet, however.
#15 | |
Bookmarks |
Thread Tools | |
Display Modes | |
