Old 09-30-2008, 03:39 PM   #1
stylEmon
stylEmon's Avatar
Stock FPR Problems: Who else...
Has anyone had problems with the stock FPR? I am curious because I am having issues with Fuel Pressure. I have an new filter, new lines from filter to rails, stock rails, 1600cc Bocsh secondaries, no pulsation dampener and stock fpr. (Walbro Hi Flow pump)
I noticed pressure issues, and took off the stock fpr. Replaced it with another stock one and am having the same issue. It's possible that both fpr's are faulty. I would even say it's probable.
Anyone have any insight or similar problems?
Obviously I want to upgrade to an Aeromotive with braided lines and AN fittings, but I don't want to spend the $600 on that right now..
Thanks
Old 09-30-2008, 06:04 PM   #2
Ender
rotors excite me
Ender's Avatar
I don't have any personal experience with something quite like your situation, but I suspect you could have fuel flow issues when two of your injectors are rated for ~3 times the flow of the stock injectors. Are you seeing the pressure drop under light load or just when you're under boost? More specifics would probably help.
'87 TII
rTek 2.1 awaits a tune
Originally Posted by need RX7
360 gamertag: quick Tii
Old 09-30-2008, 07:15 PM   #3
stylEmon
stylEmon's Avatar
not sure why that would be a problem. I have a stand alone.
The main problem is at idle. The fuel pressure is 20 psi higher than it should be. Under load it raises a little more.
Old 10-01-2008, 07:35 AM   #4
classicauto
crash auto?fix auto
classicauto's Avatar
Hmmm.
When did you first noticce the issue? Anything else changed/going on in that time period?
Old 10-01-2008, 03:26 PM   #5
TehMonkay
It's either not bypassing enough fuel or there's a clog in the line or your fuel tank is very pressurized.
Old 10-01-2008, 04:42 PM   #6
stylEmon
stylEmon's Avatar
I think its always been a problem since I had this car running after the engine build.
It was masked by other problems, or unfinished tuning... make sense?
So what causes the tank to be pressurized?
We are suspecting that my walbro is faulty... I dont want to have to buy another one (since they offer NO warranty on it) but this may be the culprit...
Old 10-01-2008, 06:44 PM   #7
jgrewe
jgrewe is on a distinguished road
Take the top off of one of your stock FPR's and put an adjustable top that is made for a Honda on it. B&M makes them, they are about $50 from Summit racing.
New rat from the sinking ship.
jgrewe is offline   Reply With Quote
Old 10-02-2008, 07:50 AM   #8
classicauto
crash auto?fix auto
Poor venting. Are you running a charcoal canister?
Old 10-02-2008, 08:48 AM   #9
stylEmon
stylEmon's Avatar
no...
Old 10-02-2008, 02:51 PM   #10
TehMonkay
So, do you just have a cap on the line on the firewall going to it?
Old 10-02-2008, 03:45 PM   #11
stylEmon
stylEmon's Avatar
pretty sure its all capped... not positive. I'll have to check it out.
So high fuel pressure is a symptom of this? What other ill effects from running no canister? or capped off lines?
Old 10-03-2008, 07:11 AM   #12
classicauto
crash auto?fix auto
Capping the vent for the tank will do some things......I'm not sure if high fuel pressure would be one of them, although its ENTIRELY possible.
All that vent's doing is essentially what the "vent" hole on a gas can does. It allows air to replace the space occupied by fuel once you start suckign fuel out. Does the reverse when you start pouring fuel in.
Its vented through the charcoal canister to keep fumes down, other wise you'd probably smell fuel coming out of the hole.
I've seen gas tanks collapse inwards from a plugged vent + heavy duty fuel pump.
Old 10-03-2008, 09:02 AM   #13
stylEmon
stylEmon's Avatar
yikes. makes sense tho.
Will look into that.
Old 10-12-2008, 10:31 AM   #14
stylEmon
stylEmon's Avatar
it is not capped off, so thats not a problem.
It is the fuel pump. I've been having issues with this pump for a while. Sometimes the pump would be really loud, other times not so loud... and it didn't matter what the fuel level was. I should've returned it months ago but now I am stuck buying another walbro!!
Old 10-12-2008, 11:50 AM   #15
SpooledupRacing
Guest
Posts: n/a
loud pump = bad pump.. sorry to hear looks like a new pump is in order.
