Old 04-07-2008, 03:29 PM   #1
Chadwick
Chadwick's Avatar
Chadwick is on a distinguished road
Using an Xcessive LIM with 99 or stock twins
Using an Xcessive LIM with 99 or stock twins:
The Xcessive LIM is not a direct replacement for the stock LIM if you plan to continue to use the stock or 99 twins. There are several things that don’t allow them to bolt right up. Here is a list of modifications that need to be made:
Oil and Water supply lines need to be bent to clear the front side of the LIM
Primary turbo compressor housing needs to be cocked about 5 degrees out for the piping that runs to the intercooler to fit. Fortunately the Pre-Control and Waste Gate actuators do not need modification if you don’t over do the rotation.
Oil fill neck needs to be heated and bent forward about ½” (thanks Rich for this tip).
UIM front bracket needs to be bent about ½” towards the front of the motor and the slot lowered (I did this with a dremel)
Secondary turbo needs about ¼” shaved off the compressor housing to avoid contacting the LIM.
Heat shield needs to be hammered in on the back of the turbo to avoid contact with the LIM.
Vacuum hard lines need to be bent to avoid the new position of the oil and water turbo supply lines.
Pressure Chamber relocated
Stock Leading coil relocated or modify UIM
Catch tank relocated if using stock Oil fill neck
93 RX7 BB (Race Car)
93 RX7 SSM (Soon to be IBM and a daily driver)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline   Reply With Quote
