Old 10-18-2011, 09:10 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Any tricks to getting front pulley hub bolt off?
The front pulley hub bolt on this engine is giving me a hard time. I have the flywheel locked with a proper tool and I heated up the bolt to break down any threadlocker that may be present. I'm using a 4' pole slipped over a ratchet (can't find the breaker bar...), and I keep lifting the engine stand off the ground and I think I bent the flywheel locking tool a little bit. Aren't these things only supposed to be torqued down to 90 ft/lb?
I'll try to get the air compressor working tomorrow so I can try to impact it off, but is there any reason it would be this hard to remove?
