Old 06-20-2011, 10:21 AM   #1
JustJeff
JustJeff's Avatar
Powder Coating overspray: help needed
Got parts back from powdercoating and there was some overspray on gasket surfaces and a couple gasket areas that they didn't mask off at all.
I'm thinking sand this down best possible and use some RTV sealant on both sides of the gaskets?
I didn't get pics of it, but I have heavier overspray on the throttlebody side of the UIM. IIRC the plastic modling between the UIM and TB doesn't use any kid of sealant and the tiny holes for vacuum lines will make using RTV tricky.
They didn't cover the turbo oil outlet port or oil cooler port (inlet??) at all:
Can I simply gasket the surface?
Oil cooler I'll have to clean up some. To make sure it seals, can I simply put some RTV on it and tighten down the hose adapter?
They also missed the BAC area on the UIM. I'm thinking I'll be ok using some RTV
Originally Posted by yzf-r1
