Old 08-16-2010, 10:15 PM   #1
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Where to place jackstands without rear subframe?
Just like the title says, I began jacking up the rear of my FC, preparing to drop the rear subframe, when I discovered I didn't know where to put the jackstands once the subframe is gone. The only place I can see is those 'rails' that run along the underside, I've always avoided using those for anything since I've seen them crushed so bad.
Immediate help would be appreciated, the car is up in the air supported by the floor jack right now .
Old 08-16-2010, 11:29 PM   #2
josh18_2k
jack it up by the diff, then put jackstands under the pinchrails. if diff is too low, drive up on blocks or whatever.
Old 08-17-2010, 12:11 AM   #3
RotorDad
Big Ugly
RotorDad's Avatar
Never mind! I agree above.
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 08-17-2010, 01:49 AM   #4
FC Zach
FC Zach's Avatar
You could also use a "snowshoe" method and place a load displacing object (whatever you want to use such as a piece of wood) between the jackstand and the body but as close to the pinch weld as possible. That's if you're worried about destroying the said area.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 08-17-2010, 06:55 AM   #5
don't touch the pinch welds, especially if there is any type of surface rust ANYWHERE.
I use the "frame" rails underneathe the muffler heat shields. If you're dropping the subframe, the exhaust is gone so it's 3 10mm bolts and the heat shields are gone exposing a VERY stong jack point.
Old 08-17-2010, 02:42 PM   #6
josh18_2k
ohh ive never pulled heat shields!
my pinch rails have been fine, but only like the rearmost 4" of it. beyond that they collapse. i have no rust tho
Old 08-17-2010, 05:20 PM   #7
need RX7
Clean S4 Nutswinger
need RX7's Avatar
I'll unbolt them bitches right now.
Old 08-18-2010, 10:50 PM   #8
NoDOHC
NoDOHC's Avatar
The rear tow hooks are another good spot
Old 08-19-2010, 12:04 AM   #9
FC Zach
FC Zach's Avatar
That's what I always use, right on the two bolts.
1993 Yamaha GTS1000
1987 RX7 Sport
1975 Dolmar KMS4
