Old 03-17-2008, 07:19 PM   #1
ppritchard
ppritchard's Avatar
Clutch Adjustment, Can it help with slipping?
OK, the clutch is definitely slipping. I have the FSM directions on how to adjust the pedal -- can adjustment make a dif with the slipping?
I'm sure we've burned some of the clutch teaching my 16 yr old how to drive a stick, but I remember being able to adjust out some amount of this (a hundred years ago).
Thanks for your thoughts.
Old 03-17-2008, 10:28 PM   #2
David Jerome
David Jerome's Avatar
Adjusting the pedal will not change the amount of pressure the pressure plate can apply. It is time for a new clutch disc and likely pressure plate if you are still using the stock one.
David Jerome
