Old 12-28-2009, 03:27 PM   #1
Justen
In Too Deep
Justen's Avatar
Fuel Pressure Regulator
Just wondering if I really need and aftermarket Fuel Pressure Regulator for a Walbro pump, or should the stock FPR in the stock secondary rail be able to handle it?
Also, I know that the stock FPR has a vacuum line coming off of it, but I don't have anywhere to attach it to because I removed all of the solenoid valves when i took out all the emissions and rats nest. So i take it that the Stock FPR would not work correctly then?
Opinions? Do I need one now that my vacuum/boost solenoids are gone? Thanks
1990 TII, fresh rebuild
Atkins rebuild kit, RA apex seals
Med. Streetport, TB mod, rebuilt turbo, ported wastegate, GodSpeed FMIC
RacingBeat Turbo-back straight exhaust, Bonez test pipe, emissions/nest removed
hks intake, Walbro, Profec B spec-2
