Old 12-27-2009, 07:13 PM   #1
Garfinkles Motor Works
Idler to replace airpump with single turbo
The idler I make is fully adjustable with a double row sealed bearing .It was designed to work with twins but by cutting the stock adjuster arm it will work with this SX setup for sure .The shorter belt is adjusted as stock,at the pulley and the alt .The unit can be adjusted for belt alinement and tension . I also made a new plate with a 90 degree fitting for the oil line to the turbo and modified the stock line so SS line does not have a loop in it as the kit had .
