Old 12-19-2009, 09:19 PM   #1
Stredrotor
Stredrotor is on a distinguished road
Stredrotor's RX4 Coupe * Project 20B *
Thought I'd start a thread on my 1974 RX4 hardtop.
I bought around 2 years ago after previously having a 13b turbo 1973 RX4 hardtop and an '86 Series 4 RX7 turbo over the last 15 years.
The car had a carby 13b and first gen RX7 5 speed, it ran well but I needed more power. I think of the RX4 as mazdas "muscle car" so it needed a engine with the muscle, hence a 20b
The RX4 as I bought it....
Striped and painted the crossmember and replaced tie rods, sway bar and bushes.
All installed!
Stredrotor is offline   Reply With Quote
Old 12-19-2009, 09:24 PM   #2
Stredrotor
The next acquisition for the 20b project, a series 5 gearbox .
I got a awesome bargain the other day, a bloke at work tipped me off to some 16 inch F90 Simmons at a second hand shop. A bit of bargaining and these were mine for $140.
All 8 inches wide.
Picked up a Microtech LTX12, coils, loom and Eboost
Just got the engine in place to work out the engine and gearbox mounts
Old 12-19-2009, 09:29 PM   #3
Stredrotor
For Fathers Day I asked for some kid free time to work on the Mazda, so I got around to doing the old shorten shifter housing mod......
Modified the gearbox cross member to suit the old RX4 one.....
Made some plates to mount the engine off and exhaust manifold flange ......
Now I just have to install the engine and box and fab the mounts off the suspension crossmember.
Old 12-19-2009, 09:36 PM   #4
Stredrotor
Here's the prototype mounts
The engine and gearbox is mounted 50mm further back than the 13b to help with clearance at the front of the engine bay.
RH engine mount now finished
And test fitted.
Left hand mount completed, sits quite nice .
Should be strong enough :!:
Old 12-19-2009, 10:12 PM   #5
Stredrotor
R/H side mount installed.....
...and L/H
Getting there
My latest purchase 60mm Tial waste gate and a GT42, ball bearing, water cooled A/R 1.06 exhaust. Now have to get in and make the exhaust manifold.
Old 12-19-2009, 11:56 PM   #6
Madaz
Madaz's Avatar
Madaz is on a distinguished road
WOW! What a project you have there. Looking forward to updates.
Madaz is offline   Reply With Quote
Old 12-22-2009, 01:24 AM   #7
Modified Dave
Modified Dave is on a distinguished road
Very nice fab work on the engine mounts, but how come you didn't throw a gusset or two on the inside of the L shape on them? Looks like there's plenty of space for a few gussets, though maybe that'd be overkill given the thickness of material used?
And a GT42?! Wowzers, how much power are you planning to make?
Modified Dave is offline   Reply With Quote
Old 12-22-2009, 01:56 AM   #8
Rogue_Wulff
Non Member
Trans mount really needs some rubber thrown in somewhere, or it's liable to have massive vibration issues.
Otherwise, awesome project.
Old 12-22-2009, 02:26 AM   #9
Stredrotor
Yea, it's now got a 10mm thick piece of rubber between the mount and gearbox bracket plus the crossmember is rubber mounted as well.
Old 01-03-2010, 05:28 AM   #10
Stredrotor
A bit more forward progress.....
Got the pipe layout sorted, think it will flow ok
Just got to sort out the transition piece on top
Couldn't help myself and did a test fit in the engine bay
Now have to have a think on how I'll plumb the wastegate.
Old 01-03-2010, 09:55 AM   #11
This is a great build you have going here.
Old 01-03-2010, 08:08 PM   #12
estevan62274
counting down till DGRR
estevan62274 is on a distinguished road
Nice!!! keep up the good work!!
Cant wait for more updates!
-74 RX-4
-84 REW GSL-SE
Past rides
-05 REW Swapped RX-8
-93 FD base
estevan62274 is offline   Reply With Quote
Old 01-11-2010, 11:55 PM   #13
13bpower
13bpower's Avatar
13bpower is on a distinguished road
Great build i like whene people put new tec on old school car,hay ma keep up the great work nice looking rx4....
13bpower is offline   Reply With Quote
Old 01-17-2010, 03:15 AM   #14
Stredrotor
Finally got a few days to make this manifold
Tacked manifold to 25mm plate to help stop distortion......
Welded and turbo bolted on.....
Fitted to engine to see how it fits.
Now to fit the wastegate pipe! .
Old 01-17-2010, 04:28 AM   #15
Stredrotor
After a lot of thought decided to plumb the waste gate straight off the collector under the turbo.
I know it's probably not the best location for flow but there was really not enough room to run three separate runners.
Here's the pipe tacked up.......
...and test fitted in engine bay.
Pipe welded on and wastegate fitted
And bolted onto engine
Next is step is to send it off to get the mounting faces machined flat.
20b, mazda rx-4
