Go Back   Rotary Car Club > Classifieds > Old School Rotary Classified
Old School Rotary Classified Pre- 1979 Rotary Classified
Old 12-14-2009, 10:48 AM   #1
Crit
Crit is on a distinguished road
FS: 74 RX-2 in Atlanta : $3,500
Here's the full run-down of the car.
74 RX-2 S122A-214666
Asking $3,500
Fully painted body shell - Original flair yellow w/ painted and cleared black stripe around the tail Absolutely all rust was removed from windshield corners and replaced
- modified to accept earlier chrome bumpers
Photos from beginning to end are located HERE.
Cragar-style 5-slot mag wheels, 13x6
Brand new HTR-200 tires - 225/13
Koni factory-rebuilt 5-position shocks and struts, installed but zero miles
Fully painted and rebuilt suspension with all new bushings, powdercoated calipers, and rear disc conversion
Full dual primary RB exhaust collects just before the rear axle, w/ 2 O2 bungs in the header
S2 RX-7 LSD
Full set of new door cards (front doors and rear inner panels) in great shape, still in boxes
Gorgeous original rear seat
Front lower spoiler (fiberglass) and trunk spoiler
All side glass and trim carefully removed and stored separately, but included.
Complete factory harness is still in the car and can be readily reused
Includes new carpet and headliner, cut to fit and still in their boxes
Original dash included, but will need to be recovered
Instrument cluster all worked when removed
Includes a junk vented hood that was dropped by FedEx. May be salvageable, but edges are bent
Car includes all the bits and pieces necessary to get it back together, including several spares for interior panels and plastic bits
Not included in sale, but available:
2 brand new windshields
Complete AC setup for RX-2
Early vented hood in nice shape
Basically, I bought the car as a runner. I drove it for several months and it was a real trip, but it had rust problems. The rust was showing past the trim on the front and rear windshields, and it drove me crazy. It honestly ruined the car for me. I took the car all the way down to nothing, minus the dash structure and wiring harness (harness was pulled in from engine bay and trunk, and balled up at the passenger's seat. It's still routed through the dash and is complete).
Since I was living in an apartment, I stored the car, put away all the trim, interior bits, glass, etc. at my parents house and started collecting parts. I got an internally regulated alternator, found some interior pieces that were nicer than mine on ebay, and began rebuilding the suspension.
The rear end was removed, painted, new bearings installed, S2 small-bearing LSD installed, and put back under the car. I think the drum hardware is back on the axle and the rear calipers, rotors, and brackets are still in boxes after being powdercoated. I rebuilt the calipers, since you can't bake the rubber seals, but the rears haven't gone back on.
I then rebuilt and painted the steering box and front end, with all-new tie rods and ball joints sourced from Australia. Ditto for the all-urethane suspension bushings. The shocks and struts were shipped off to Koni after they told me that they haven't seen them in years, but should still have seals and valves to rebuild them with. They did a one-off job for me and rebuilt the adjustable shocks and struts. I then reassembled the front end, including the new powdercoated calipers, and installed the rear shocks. That's how the car sits now, without the brakes plumbed and all the suspension under her.
All the interior is in my guest room upstairs, well-protected from tools, animals, etc. The stainless trim (very little was actually chromed) is hanging high on the walls of my garage and shop, so it won't get damaged. The hood is perfect, but I've also got a junk hood that I wanted to cut an oval in and poke the Weber up through, but that's still a good way down the road.
When the car was being trailered back from the body shop, it came off the trailer, and the last corner to leave was the front-left. As the wheel came off the trailer, the car came down and bent the left fender and valence, both 15-minutes old. They're both salvageable, but I've sourced a new fender as well so the body shop can choose to either repair the current or prep and paint the new.
I've got the exhaust stored out of the way, but it's also complete, down to the NOS Racing Beat exhaust gaskets. I wanted to run independent Air/Fuel mixture gauges in the header, so it's been drilled and welded to accept them, then powdercoated with a chrome-looking ceramic finish. If you don't want to utilize the O2 sensor bungs, you could either stick in used )2 sensors, or replace with a plug.
The battery tray was removed from behind the front-right high-beam headlight for three reasons. 1 - it looked ugly there. 2 - it makes room for a turbo, and in the perfect spot for a rotary turbo 3 - weight and balance. I never intended it to be a drag car, but with a car this light, it would be sweet to relocate the battery to the trunk.
If you have any questions, feel free to ask. The short answer is that the whole car is here, with clean title and all door locks the same, it just needs to be screwed back together. I've even got parts manuals and service manuals that are scanned and hosted that I'd be happy to share with you.
Crit is offline   Reply With Quote
Old 12-14-2009, 12:41 PM   #2
RotaryRoadRage
RotaryRoadRage's Avatar
RotaryRoadRage is on a distinguished road
Wow.. Very nice!
89 TII black on black
Gamer tag - graveconditions
RotaryRoadRage is offline   Reply With Quote
Old 06-14-2010, 06:30 AM   #3
13BMW
13BMW's Avatar
13BMW is on a distinguished road
wonder what it would cost to get this puppy to Australia
13BMW is offline   Reply With Quote
Old 06-16-2010, 08:54 AM   #4
Proxy One
Victory Is Mine
Proxy One's Avatar
Proxy One is on a distinguished road
This car is sold.
www.dealsgaprotaryrally.com
1994 Rx7 White 2001 RZ GT35R'd
1972 Rx2 Orange Coupe 5spd
2006 STi
1986 Buick GN
Proxy One is offline   Reply With Quote
