Old 12-13-2009, 06:59 PM   #1
amunoz944
amunoz944 is on a distinguished road
my new twins
my new upgraded twins custom done by elliot at turblown performance. www.turblown.net
amunoz944 is offline   Reply With Quote
Old 12-13-2009, 09:10 PM   #2
05rex8
Turbo 8
05rex8's Avatar
05rex8 is on a distinguished road
lookin' good!
05rex8 is offline   Reply With Quote
Old 12-13-2009, 10:49 PM   #3
amunoz944
Originally Posted by 05rex8 View Post
lookin' good!
Thanks
Old 12-13-2009, 11:31 PM   #4
Mobius
Rotorhead
Cool setup. What are the specs on the turbos?
Other than ease of fabrication, what are your thoughts behind running a turbo off of each rotor rather than doing an X-pipe type of merge and then going with equal length runners to each turbo? How is the spool with this type of set up?
Have you had it dyno'd yet?
Old 12-15-2009, 07:14 PM   #5
prrex4ever
prrex4ever's Avatar
Different but interesting. What are the advantages over a stock set-up other than the turbo capabilities?
Old 12-16-2009, 04:43 PM   #6
classicauto
crash auto?fix auto
classicauto's Avatar
Loves it.
Old 12-17-2009, 08:56 AM   #7
I really want to see some dyno numbers and torque curves. I thought about something like this for the FD but found that the torque seems to come on about as fast as a properly sized single. That was the case with Howard Colemans setup and the twin GT28 setup that Jason did @ RX7 store.
what are the specs on these turbo's if you don't mind me asking?
Old 12-18-2009, 02:13 AM   #8
amunoz944
50 trim Garrett To4E(s) mated to a .63 T3 with a stageV turbine wheel. Oil cooled only with a 360 thrust bearing upgrade. Turbine housings have been modified for 3" vband.
Twin 3" 304SS vband downpipes merging to a 4" midpipe
Hard lined oil feed and return lines
Twin Tial 38mm wastegates venting to atmosphere with -AN SS braided Teflon lines
100cc pre compressor 50/50 water alcohol injection, and 600cc post front mount
Tial 50mm BOV
Turblown lower intake manifold Heatshield
Old 12-18-2009, 02:16 AM   #9
amunoz944
The car is still under construction and i will be posting dyno results, expected dyno is within the next 2 weeks or so. thanks for the compliments guys.
Old 12-18-2009, 08:00 AM   #10
Can't wait to see some numbers!
Old 12-27-2009, 11:36 AM   #11
amunoz944
nice 20b cosmo I'm jealous
C
Old 01-03-2010, 02:26 AM   #12
amunoz944
okay guys driving with the twins is pretty amazing. still not tuned properly but boost comes on at 1700 rpms and climbs really fast.
Old 01-21-2010, 01:17 AM   #13
glenrx7
glenrx7 is on a distinguished road
Not to be a thorn in anyones side but is elliot planning on coating everything?? and I would make sure there is some kind of bracing thin pipe like that wil a turbos wieght is going to lead to cracks in the near future...cool set up, almost went t04s twins on my car but opted for a custom 4088...keep us posted
glenrx7 is offline   Reply With Quote
Old 01-21-2010, 03:35 PM   #14
1Revvin7
Turblown Engineering
1Revvin7 is on a distinguished road
The owner is planning on having heat shields made for everything down the road. If it were up to me everything would have been done, but I'm not the one paying for it
The manifold is braced, its just not in the pictures. All of the tubing is .120" wall.
1Revvin7 is offline   Reply With Quote
Old 01-22-2010, 01:11 PM   #15
Haven't seen a post from Elliot in a while, glad to see you all are still steady working on projects!
Interested to see the #s on this one.
turblown twin to4
