View Poll Results: December Rotary Race Car Of The Month!
Chadwick's RX-7 29 43.28%
The PartsGroups RX-8 6 8.96%
Sarah/BMIRacing 4 Rotor RX-8 32 47.76%
Voters: 67. You may not vote on this poll
Closed Thread
Old 12-13-2009, 04:50 PM   #1
ZGN
Administrator
ZGN's Avatar
December Rotary Race Car of the Month Voting
Chadwick's RX-7 From Smyrna, TN, USA
1993 Brilliant Black Base RX7.
Engine and drive train and suspension
13B-REW
Rx8 eccentric shaft
9.7:1 rotors (89-91 NA) balanced and lightened
Rx8 front and rear Stationary gears and bearings
13B-REW front and rear counter weights
Balanced and clearance for 9k+ rpm
Ported intake and exhaust without changing timing
Port matched intake runners
Xccessive Manufacturing lower intake manifold
JDM upper intake manifold
Oil and Water mods
Re-medy water pump
550cc primary injectors
1680cc secondary injectors (RX7-Store fuel rail)
Garfinkle Oil pan brace
Smurf engine mounts
Mazdaspeed power plant frame
Tweakit Racing Intercooler and Duct
FJO injector driver
FuelLab 525 Series FPR
SR Motorsports wide belt underdrive pulley kit
99 spec twin turbo /w ported wastegate
R1 duel Oil Coolers
Tweakit Racing Idler Pulley
HKS Twin Fire
Magnacor 10mm Race wires
Koni Sport custom valued and converted to double adjustable.
800lbs front, 560lbs rear springs
Nagisa Auto Upper Control arms
RP Trailing arms
RP toe links
Unotainium bushings
4.77 Knightsport ring and pinion
Kaaz 1.5 LSD
Fuel tank surge cover
Axiom harness bar
RP Nippondenso Fuel pump
Widefoot Swaybar mounts
M2 Carbon Fiber CAI
Mazdacomp radiator
Body
99 front bumper
99 bumper reinforcement 99 undertray
99 brake ducts
99 air guide
99 combination lights
99 front chin spoiler
99 rear tail lights
RE replica oil cooler ducts
Feed replica side skirts
Tweakit Racing Custom Front Splitter
Mazdaspeed replica hood
APR GT 2 custom 2 element wing /mounted using stock R1 holes
Flying “M” badges front and rear
Interior
Corbeau Forza w/ dual lock slider (Driver)
Corbeau Clubman /stock rail (passenger)
Lilliput in dash Carputer
Lilliput 7” retractable in dash touch LCD
Tripower gauge pod
LC1 wideband w/ XD-16 gauge
Pineapple Dual EGT gauge
Pettit column mount boost gauge
The PartsGroups RX8 SCCA ITR & NASA PTD Race Car
This car was built this year and has had several wins in SCCA & NASA racing events. It just won overall in the 2009 American Road Race of Champions 3 Hour Enduro at Road Atlanta and is 1st in class in SE NASA PTD. The classes I race this car limit what you can and can not do.
Here is a quick list of some mod's:
  • Custom radiator
  • custom water pump
  • custom intake for racing with SCCA
  • rem coated 5:12 ring & pinion
  • aluminum clutch
  • ecu tuning
  • custom roll cage
  • fuel tank mods to eliminate fuel starvation
  • required safety equipment
  • AEM dash,blueprinted injectors
  • custom fuel rail
  • custom made shifter bushings
  • KONI custom shocks
  • custom sway bars
  • custom exhaust headers for SCCA
  • custom exhaust
  • sunroof roof panel removed and replaced with non sunroof panel
  • 17x8.5 Enkei RPF1,Hoosier R6 Tires in various sizes
Sarah @ BMIRacing's 4 Rotor RX-8
2009 Mazda RX8 4 Rotor
Engine and Accessories
Naturally Aspirated Peripheral Port 4 Rotor
NRS 2 piece 2mm Ceramic Seals
Mazda Dry Sump Front Cover
4 x 1200cc RC Injectors
Fuel rail supplied by RC Injectors
Slide Throttle
K&N Air Filters
Custom Carbon Fiber Air Box
Haltech Sport 2000
Racepak IQ3 Data Logging Dash
Griffin Radiator with oil heat exchanger
2 x Davies Craig Electric Water Pumps
2 x Davies Craig 16" Electric Fans
2 x Davies Craig 12" Electric Fans
Burns Stainless Headers, 4 into 1 Collector, Transition and boom tube
2 x Bosch Motorsport Fuel Pumps
Fragola Performance Systems - Fittings and hose for the Oiling System and Fuel System
Hose Techniques - Intake System, and cooling system
Pure Power Lubricants and Stainless Steel Filters
Drive Train
Tilton triple plate carbon carbon clutch
Tilton Flywheel
Tilton Bell housing
Tilton Super Starter
4 Speed EMCO Transmission
ACPT Custom Carbon Fiber Drive Shaft
1 1/2 way Tomei Limited Slip Differential
Accessories
Progress Auto front and rear sway bars
Fragola Performance System Brake Lines
Disc Brakes Australia brake rotors front and rear
Brembo Brake Calipers
Tilton 600 Series Pedal Assembly
Tilton remote adjustable brake bias
MOMO Steering wheel
MOMO WTCC Quick release hub
MOMO Safari Racing Seat
MOMO 6 point Safety Harness
Lexan Windows
8 Point Roll cage
AIT Racing Carbon Fiber Hood
AIT Racing Carbon Fiber Doors
AIT Racing Carbon Fiber Trunk
AIT Racing Carbon Fiber Roof
AIT Racing Carbon Fiber interior panels
APR Performance GTC-500 Adjustable Rear Wing
APR Performance Rear Diffuser
APR Performance Front Splitter
Odyssey Battery - Extreme Racing 30
3 x GoPro Motorsports Hero Wide Angel Camera
Kevin
ZGN is offline
Old 12-13-2009, 11:00 PM   #2
MIKES'8
MIKES'8 is on a distinguished road
that 4 rotor is sick seen it at 7stock!
2005 MAZDA RX8-THE WEEKEND WARRIOR
2008 MAZDA CX7-THE FAMILY RIDE
1994 MAZDA MIATA-THE CLASSIC(36K ORG MILES)
1992 MAZDA 929-THE VIP PROJECT
1989 MAZDA MX6-THE DAILY
MIKES'8 is offline
Old 12-13-2009, 11:28 PM   #3
Had to vote for this years Solo National SSM Champ Dan Chadwick.
85rx-7gsl-se is offline
Old 12-14-2009, 11:07 PM   #4
Monster_FC3S
7 NOOB
Monster_FC3S's Avatar
Monster_FC3S is on a distinguished road
BMIRacing's 4-rotor FTW! But still a hard1 Chadwick's is sick to (Would love to see one of them at the next deals gap meet!! woot woot)
MØ₦$ŦEƦ_₣₡3$
Monster_FC3S is offline
Old 12-15-2009, 07:54 AM   #5
Chadwick's was at DGRR last year. I believe he will be back this year.
djmtsu is offline
Old 12-15-2009, 07:06 PM   #6
prrex4ever
prrex4ever's Avatar
Another tough decision. Luv the 4 rotor but.......!
prrex4ever is offline
Old 12-15-2009, 07:27 PM   #7
Chadwick
Chadwick's Avatar
Yep, Tweakit Racing is sponsoring DGRR again so we will be there!!
93 RX7 BB (Race Car)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline
Old 12-15-2009, 10:12 PM   #8
Monster_FC3S
7 NOOB
cool see you guys there!
MØ₦$ŦEƦ_₣₡3$
Old 12-15-2009, 11:01 PM   #9
Brent
Sua Sponte
Brent's Avatar
Look for the guys with the huge wings! There may also be another TweakIt car there
Voted for Dan as well. All very nice cars this month and I love seeing this race car rotary month.
Brent is offline
Old 12-21-2009, 04:08 PM   #10
Pourman
Pourman's Avatar
DANG that 4-Rotor sounds sick !!
Pourman is offline
Old 12-22-2009, 08:25 PM   #11
fc nut
member
that thing is music to my ears. it's sweeet!
fc nut is offline
Old 12-23-2009, 03:49 PM   #12
RotorDad
Big Ugly
RotorDad's Avatar
Gotta love the 4 rotor!!!
Boosted Big Body On 335's
PS3 ID: Rotordad
RotorDad is offline
Old 12-28-2009, 10:01 AM   #13
ZGN
Administrator
ZGN's Avatar
Only a few more days left to get your vote in! It's a close race between the FD and the RX-8
Kevin
ZGN is offline
Old 12-30-2009, 10:38 AM   #14
Bryan@BNR
Bryan@BNR is on a distinguished road
Is BMI a member on this forum? I know chadwick is so I voted for him.
Bryan@BNR is offline
Old 12-30-2009, 11:02 AM   #15
ZGN
Administrator
ZGN's Avatar
Yep, they are!
BMIRacing
http://www.rotarycarclub.com/rotary_...ight=BMIRacing
Kevin
ZGN is offline
Closed Thread
