Old 03-16-2008, 02:29 PM   #1
ppritchard
ppritchard's Avatar
How much oil for the shifter resovoir? (pic)
Does oil just belong in the small area where the ball sits or is it supposed to be more than that? Also what type of oil? Does it make its way into the transmiission or is this area sealed in some way?
Old 03-16-2008, 06:21 PM   #2
a7xh7
a7xh7 is on a distinguished road
oh the thread is here too
fill high enough to the top lip of the inner circle where the shifter bushing sits. fill both inner and outer.
"sevens_ix"
a7xh7 is offline   Reply With Quote
Old 03-16-2008, 07:23 PM   #3
ppritchard
ppritchard's Avatar
Thanks! and double thanks for checking more than one site!
Old 03-16-2008, 07:26 PM   #4
ppritchard
ppritchard's Avatar
What type of oil is the best for this area? My notes say tranny oil, but I'm not sure if this resovoir is all by itself or somehow intersects with the tranny. Don't want to mess anything up. Plus -- is tranny oil the same thing as automatic transmission fluid or is it a regular oil?
Old 03-16-2008, 09:47 PM   #5
a7xh7
its not the same as auto tranny fluid. its not regular oil either. its tranny fuild.. 75w-90 gear oil, use it
"sevens_ix"
Old 03-17-2008, 07:11 PM   #6
ppritchard
ppritchard's Avatar
Whatever you are using in the tranny is fine. Most say Redline or Amsoil.
I went to Pep Boys and they didn't have the Red Line, but they had a couple of gear oils in the same viscosity, the one I got was labeled as a synchro type oil.
Put it in up to the level and the shifts are pretty smooth. Probably doesn't make as much difference as changing the tranny to a synthetic, but it does help.
Old 03-19-2008, 09:09 AM   #7
Signal 2
Viable Fossil
Signal 2's Avatar
Liberally grease the ball pivot and lower bushing too.
Old 03-19-2008, 11:04 PM   #8
FD3S2005
FD3S2005 is on a distinguished road
i dont think i have any in my shifter last time i looked
FD3S2005 is offline   Reply With Quote
Old 03-20-2008, 12:54 AM   #9
McVicker
McVicker's Avatar
McVicker is on a distinguished road
I would replace it with a new one while the shifter is out, if you are installing a new shifter/short shifter. I think someone makes an upgraded one, but OEM works just fine.
Scrubs McBubs!
SakeBomb garage.com
McVicker is offline   Reply With Quote
Old 03-22-2008, 03:36 PM   #10
Signal 2
Viable Fossil
Signal 2's Avatar
I think the FSM specifies grease on the lower pivot-bushing as well as the main ball pivot. Someone once suggested marine grease as it might adhere better in the gear oil bath. I've never tried it, but it couldn't hurt.
Jim
VR R1 FD
