Old 11-24-2009, 12:27 PM   #1
brycerxer
brycerxer's Avatar
brycerxer is on a distinguished road
under-heating problem?
This one has me scratchin my head: I had a coolant leak on my SE (the hose from the firewall that goes to the driver's side of the engine was leaking). After fixing the leak by cutting an inch or so off the bloated end of that hose and re-attaching, I flushed the system with a garden hose at the top of the radiator with the engine plug removed till it ran clear (lots of crud came out). I also checked the connection at the temp sensor before refilling w/ 50/50, bleeding, etc.
All is well, almost -no leaks, remove all the air bubbles etc. However, the temp gauge on the dash doesn't go nearly as high as it did before. It used to go to a straight down position after full warm up. Now it barely goes beyond the second of the two lines on the cold side, then gets even colder as I drive it.
I'm thinking replace the thermostat first. I hesitate to think its the temp sensor since it worked fine before. What do you guys think? Has anyone else come across this before?
'85 RX-7 GSL-SE Current Driver
'85 RX-7 GS Current project
'84 RX-7 Parts car-SOLD
'91 RX-7 VERT SOLD
brycerxer is offline   Reply With Quote
Old 11-24-2009, 10:21 PM   #2
moremazda
shookmotorsports.com
moremazda is on a distinguished road
Replace the thermostat just for good measure, but that is where my SE sits even when on track. It would come to the half way point only when the A/C was on in traffic.
moremazda is offline   Reply With Quote
Old 11-24-2009, 11:34 PM   #3
RotaryProphet
I would think after flushing crap out of the coolant system, you would -expect- it to run a bit cooler, no?
Old 11-25-2009, 02:37 PM   #4
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Temps are normal now. If a lot of crap came out you possibly cleared out some blockage. You may have also gotten some trapped in the thermostat(sticking open). Back flushing can be good and bad. But you are running normal now. Mine runs in the bottom 1/4 with new radiator and water wetter.
Old 11-25-2009, 04:14 PM   #5
Pro ViZion
Run DAMN YOU!!!
Pro ViZion's Avatar
Pro ViZion is on a distinguished road
That's where mine is at as well.
www.VegasRotary.com - Vegas' local rotary car community!
Pro ViZion is offline   Reply With Quote
Old 11-28-2009, 07:26 PM   #6
brycerxer
brycerxer's Avatar
I replaced the thermostat w/ a $10 Duralast from Autozone. The one I took out was shorter- it didn't reach the small hole at the bottom, but the new one does. Cleared out more junk at the radiator hose outlet. Now it warms to just past the second line, then settles back to on that line. Thanks for the input. I didn't realize that was normal. I think I'll do another flush in the near future as this was obviously neglected for a long time.
'91 RX-7 VERT SOLD
Old 12-01-2009, 12:20 PM   #7
rx4ur7
Rotary since 1972
rx4ur7's Avatar
Well there was your overheat issue. As everyone knows the standard thermostats do not block off the bypass so you do not get full flow through the radiator when it opens. The reason for plugging that hole for racing when you run without thermostat.
Old 01-04-2010, 09:29 PM   #8
yellowstonepart
Guest
Posts: n/a
Yellow stone diesel parts plant is one of the leading manufacturers
of engine parts, in particular diesel fuel injection system
accessories for replacement, such as Fuel injection Nozzle, Plunger and
Delivery valve, ETC In south of china .
for more detail please visit our website : www.yellowstonediesel.com
www.dieselinjection.cn
Yellow stone diesel parts plant was founded in 1997.Over the years,
Yellow stone has grown and gained a reputation for producing
high quality products and delivering them on time.
