Old 11-18-2009, 02:45 PM   #1
Custom Brake Rotor hats..
I'm curious.. Is it hard to get custom brake rotor hats for 2 piece rotors?
Old 11-18-2009, 04:45 PM   #2
I don't know man. That is a precision piece, which would also carry alot of liability on the part of the manufacturer.
Old 11-18-2009, 05:49 PM   #3
What are you trying to accomplish Phil? If you're looking to replace some stock rotors with two piece rotors, than the manufacturer of the 2-piece rotors should have already taken all the measurements etc for the hats and rotors themselves. If you're looking to have one made off of an existing rotor, then you should be able to send them the rotor that you're looking to replace and they should be able to replicate the offset etc.
If you're looking to have a custom setup made, you should be able to send them a knuckle and the rim you're using and they should be able to build everything needed. Hats, rotors, adapters etc.
Old 11-22-2009, 11:55 PM   #4
Flys
Flys is on a distinguished road
Try Wilwood's site, I remember reading on there some where about custom hats. Or browse their selection..
http://www.wilwood.com/HatList1.aspx
Flys is offline   Reply With Quote
